Question about DeLonghi MW 605 Convection/Microwave Oven
DeLonghi combination microwave 900w
My problem is that when I use the oven I have to set it at least 10 degrees more than the food instructions and also leave it for at least 20 minutes longer. Is this a fault or is it just the way the oven works?
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
SOURCE: my LG microwave does not heat food ,spins but makes noise
high voltage fuse blowed
Posted on Oct 27, 2008
bestdarngood
  • 3037 Answers
SOURCE: it turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
  • 97 Answers
SOURCE: MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Posted on Jun 10, 2009
SOURCE: AC925EQK microwave. flashing light, not heating up
Mag tube Shot
Posted on Aug 29, 2009
Testimonial: "thanks very much"
I am looking for a Delonghi P90d25 25L 900W Standard Stainless Steel Microwave manual
http://www.delonghi.com/en-us/customer-service/instruction-manuals
Go to the above website. It shows you the information you need to enter and you will have access to the manuals. They want the product number.
Good luck.
Semper Fi,
Z
Apr 26, 2017 | DeLonghi Microwave Ovens
My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Sep 04, 2011 | DeLonghi Microwave Ovens
I have been given a DeLonghi 850 Microwave but have no instructions - is it possible to get some. It has a serial number of ED8525S-SBD. I tried to heat something but it wouldn't think I must be using the...
try looking for your manual here: http://www.delonghiusa.com/index.php?texts&pid=10
If you can not find it, try calling their customer service, and ask them to send you a manual!
help@delonghi-csservice.com
1 (800) 322-3848
Sep 09, 2009 | DeLonghi Microwave Ovens
It turns on ...lights up but doesnot heat or warm the food
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
DeLonghi MW 605 Convection/Microwave Oven Logo
193 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
