Question about Creative Labs ITrigue 3400 2.1 Speaker White Computer Speakers
Stopped working. I-trigue 3400
Speakers stopped working. No sound from sub-woofer or satellites.
Power supply tests good.
I haven't done a continuity check on the internal fuse but it looks good to the eye.
The speakers are about 3 years old
  • 2 more comments
  • kevjoamy Dec 06, 2008
    I have the same problem with my speaker setup. They suddenly stopped working. I sent them to a friend who was going to see if he could find the problem but he never got round to looking at them for a few weeks and when he did found them to be working perfectly. I had them back and after about 3 weeks they stopped working again. I have no idea what is wrong with them, a dodgy connection inside?
  • cynandude Dec 18, 2008
    same situation with me. they stopped working all of a sudden and fuse is OK. Is there a fix?
  • Anonymous Apr 27, 2009
  • ainglis85 May 09, 2009
    Sound went really low, then went out completely within 30 seconds. Checked all connections and still wouldn't work. Unplugged and replugged power source and this go it working once again, but went out within an hour. Hasn't been playing any sound ever since. All wires, speakers, etc. treated lightly and appear in very good condition.
    Problem Solver:
  • 12 Answers
The stereo -jackbus is broken if your speakers won't work and your headphones are fine. The stereo jackplug holds a little switch at the back, which moves sideways if you connect headphones.
Solution is very carefully opening back end of stereo connector bus and reassembling the switch
Posted on Apr 26, 2010
    Problem Solver:
  • 5 Answers
A simple test to begin with is to turn the unit on (with or without the PC connected) and then quickly remove and replace the power jack form the back of the subwoofer a couple times. If you cannot hear and feel the pop/thump of the subwoofer, then test the output of the power supply, it should be about 13.5VAC (not DC). If you have good power, and no thump, your amplifier is likely toasted.
If you hear the pop/thump when you plug/unplug the power, then you're in good shape because the power supply and amplifier are working.
Odds are that the issue is mechanical and easily fixed. Bad jacks on the back of the subwoofer or on the remote, damaged cables, or a bad volume control (potentiometer). On the 3400 I just fixed, someone had yanked the remote cable, stretching and breaking a couple fine wires inside the remote
Posted on Feb 05, 2014
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
VGP-sp1
just do as I did cut the cable and attach to a store bought power adapter works good. I am only using a 12v power adapter and it seems to work fantastic
May 13, 2012 | Sony Audio Players & Recorders
The speakers work fine apart from the sub component has lost all volume u can hear it very faintly if u turn the volume to full and the bass control to max. I've taken the sub apart to some extent...
Appears that the map powering the sub woofer is fubar. Those amps take a beating usually from being over driven. Transistors are not like tubes that will just reach a limit, distort, and stay there. You push a transistor and it will self destruct since it knows no limits ala evel knevil.
Sep 20, 2017 | Creative Labs i-Trigue 3400 Computer...
My I-TRIGUE 3400 wont work with windows 7 unlimate 64 bit
Hello
First be sure you have downloaded and installed the correct sounddrivers.Meaning win 7 64 bit.
Not to be confused with 32 bit.You need 64 bit.
Next go to control panel,sound.Click on speakers then configure.Choose quadrophonic or 5.1.
Then run a test on each.
Also go to properties.and be sure the levels are turned up.
You may need to reboot after you do this for sound to work.
Sep 22, 2011 | Creative Labs i-Trigue 3400 Computer...
No I cant get my sub woffer to work woofer.There is power to the unit .I am trying to connest it to a sound bar which has a sub out.
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
Jul 29, 2011 | Proficient S12 Subwoofer
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
My Creative I-Trigue L3800 speakers have stopped working. The system receives power (the volume control lights up) but I am no longer getting any sound. I fear something may have blown but not sure what. I...
don't know but i'm in the same boat. the white connector on the subwoofer does not receive sound. either the left or the right speaker will work when plugged into the red female connectors but neither works with the right. fuse is all i can think of. know where to get one?
Oct 29, 2009 | Creative Labs I-Trigue L3800 Computer...
Sound is pulsing.
You probably have the power bar thing too close to the sub woofer, this will cause a pulsing sound! :D
Apr 04, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
I-trigue 3400 speakers
My 3400 worked yesterday, but today the subwoofer stopped working. I tried a lot of different things. In the end, I simply had to jiggle the wired remote connection to the subwoofer and it started working again.
Jan 07, 2008 | Creative Labs i-Trigue 3400 Computer...
No sound no nothing !
make sure :
1- the the speakers are connected to the sub woofer correctly
2- the sound driver is installed on your computer ( you can check that from Device Manager )
3- that you connected the sub woofer jack to the correct jack of your computer
4- the volume parameter is set to highest in your computer
if nothing works out then i suggest connecting the speakers to another device ( like ipod or mp3 player )
if either this won't work then the speakers are obviously corrupted :)
Dec 25, 2007 | Creative Labs I-Trigue 3600 Computer...
490 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
