Question about Sylvania LC420SS8 LCD TV
Remote sensor on tv not responding
I,have to turn on tv manually. change input manually,tv reception is ok. Volume cannot be controlled,it will lock in at full volume or drift back & forth,mostley full volume. If I use volume buttons on tv , it changes input (video 1 pc hdmi & so on) Once in a while setup screen will appear then disappear. I have changed batteries in the remote, I don`t believe this is the problem.When tv is first turned on the volume icon at bottom off screen will go from 0-60 and hang. since I cannot get remote to work with tv I can`t use mute button. The problem apppears to be in the tv itself?
  • 2 more comments
  • john jundt Feb 12, 2012
    In reply to your answer. what exactly is the s/w on the tv? Also the screen is flashing thru all the input modes constantly. I hear a humming sound for a few seconds then nothing. this seems to keep repeating itself every few seconds. Thanks for your reply.
  • john jundt Feb 13, 2012
    It appears that the volume is locked on at full volume, thus making a humming sound in the speakers about every 5 seconds or so. manual volume control has no effect.
  • john jundt Feb 14, 2012
    Problem solved. the problem was in the manual controls on tv. I bypassed the controls, the remote worked perfect. The tv is back up and running perfect minus the manual controls on the tv which was causing all the problems in the first place. Down the road I may replace the control board, but right now every thing is working fine. I just need to be sure and keep batteries on hand for remote. Again ,thank you for your reply. John
  • vhernandez1
    vhernandez1 Jul 07, 2012
    John, I have the identical problem - How did you bypass the manual controls?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
The problem is the s/w on the tv if you have some solder experience this is easy to fix just repalce the s/w
Posted on Feb 12, 2012
Testimonial: "Thanks to Jose Garcia for his reply to my problem. He was right on!!!!"
  • vhernandez1
    Jose, what is the s/w and where is it found?
How to remove code set 3 for the remote control panasonic bd-45
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
[RECEIVER j VOL].
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
receiver.
Feb 20, 2016 | Panasonic Televison & Video
Samsung LN46B530P7f. Tv not respond to remote or channel volume buttons tv changing channels and volume on its own
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 01, 2014 | Samsung TV Remote Control
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control
for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote
control for more than 3 seconds.
9.1.2. Exit
Disconnect the AC cord from wall outlet.
This is straight out of the service manual.
Regards,
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Remote sensor on tv not responding I,have to turn on tv manually. change input manually,tv reception is ok. Volume cannot be controlled,it will lock in at full volume or drift back & forth,mostley...
Have you checked your remote to see if its working? If you have a digital camera or camera phone, point the remote at the lense and see if it shows up on camera screen. If it is working then the IR sensor on the tv could be bad.
Jul 17, 2012 | Sylvania LC420SS8 LCD TV
My TV will not respond to the remote.
Hello
Do check the infrared emission from your LG remote control. Just to to this link, where you can see details about it. If infrared emission is there, and still TV does not accept it, the infrared sensor inside your TV is faulty and should be repaced. Ok
http://www.fixya.com/support/r8733688-common_faults_in_infrared_type_remote
Nov 18, 2011 | LG 37LC7D 37 in. LCD HDTV
I have an Apex televsion, model no. AT3208S. My remote control buttons are not working correctly...nor are the buttons on the front panel of my TV. I can turn up the volume but can not turn down the...
IT is not available in the elect market,soyou connect one set topbox through audio/video input socket then you can change with the help of set top box remote.
Aug 02, 2010 | Daewoo Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Can't turn off tv
Remote sensor problem.
Jul 12, 2009 | Directv RC23 Remote Control
Sylvania LC420SS8 LCD TV Logo
385 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
