Question about Frigidaire Affinity ATF7000E Front Load Washer
How do i get LOC to go off on my washer - Frigidaire Affinity ATF7000E Front Load Washer
How do i remove the loc code
I appreciate your post, friend!
Based off the information you have provided you are receiving a "LOC" code on your Frigidaire washer. "LOC" typically means that your control lock feature is on to remove the lock feature you need to hold down the options and select buttons for ten seconds. I hope this is helpful. -Matt
Feb 17, 2015 | Frigidaire ATF6000ES Front Load Washer
Loc coming up on frigidaire washer front load
The controls have been locked unintentionally and this is a safety feature to avoid having someone accidentally stop the washer or modify the cycle. It can be unlocked by pressing and holding the OPTIONS and SELECT buttons for 10 seconds or until the "LOC" is no longer displayed. Lock the controls with the same buttons and in the same way until "LOC" is displayed alternately with the estimated cycle time.
Jun 19, 2011 | Frigidaire ATF6000ES Front Load Washer
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
417.44092500 front load washer I get a LOC err,
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
LOC Blinking
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC-Can't start my washer
Ok, press Options and Select at the same time and hold for 10 seconds until "LOC" is no longer displayed. Your control lock was engaged.
Nov 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
