Will not power down.
Replaced MB, HDD,CPU,fan. Put it all back together. No boot. Black Screen. (no screen activity, noPOST). HDD spins up, fan runs. won't power down.
  • Bob Franks Feb 14, 2012
    New RAM Crucial 1gig, upgrade for MX3562 Gway LapT. Right out of the blister pack. Rechecked all connections 2x. Symptom before action was: Screen boot to load up XP. Stopped dead... straight to BSOD. Blacked out too fast to read notice. Prompted me to replace all parts. New charger, full charge. Tested switch. ANY suggestion gratefully accepted.
  • 32,281 Answers
The RAM module/s maybe faulty.
Thake the RAM module/s to your friendly computer repair shop and get them to test the RAM.
Posted on Feb 13, 2012
3 Suggested Answers
Davethesnake
  • 689 Answers
SOURCE: My notebook (ASUS A6jc) BIOS does not boot only
if its less that two years old asus will collect and repair it within 7 days just ring this number 0870-120-8340 you might have to prove date of purchase etc sound like a serious malfunction possible cause corrupted downloads
Posted on Sep 05, 2010
  • 2567 Answers
SOURCE: My Dell M65 will not boot the OS when turned on.
Did you try to power it up with the battery removed?
Posted on Dec 01, 2010
Ga-h55m-s2h board not booting, nothing on screen . cpu fan spins and everything is indicating activity. Post give 1 long beep and 2 quick. phase leds 1 and 2 green, 3 orange, 4 red
Just had the same problem, same board. This mb does not play well with all types of RAM. I had a single 2gb Patriot dimm and it did the exact same thing, removed the RAM and it would boot but no screen. Replaced the single dimm with 2 - 1gb dimms and it booted right up with no problem. Hope this helps.
Mar 10, 2010 | Gigabyte Computers & Internet
New build pc no boot... black screen
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Nov 17, 2009 | ASUS M2N-MX Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Can't boot up my acer 290 notebook as the screen is
Hi,try making sure your heatsink is properly seated on your cpu chip with some cpu compound between them......I had a laptop that did the same & when i checked the cpu heatsink & fan i noticed the screws holding down the heatsink onto the chipset had come away so i applied some compound to the centre of yhe chip reseated the heatsink with longer screws & i also gave the heatsink & fan a good clean,put it all back together & it worked fine...goodluck
Jun 06, 2009 | Acer TravelMate 290 Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
P105-S6014 Fan runs on start up, black screen, no picture.
Remove all parts from the motherboard PCI slots, AGP slots and such, including all drives and RAM memory sticks.
If you still cannot get to a boot screen, have the power supply checked out or get a power supply tester ($25 at most) and test it yourself. If it checks out OK, then try swapping your CPU out into a similar computer to test it.
If the CPU works, disconnect everything from your motherboard other than the power, this includes all RAM (memory) sticks any hard drives floppy cd, etc.
Boot the PC and see if you at least get to the BIOS boot screens (White type on a black bacground) If you do, then put them back one at a time, rebooting each time. This will allow you to narrow the problem down to the part causing the problem.
Replace the problem part.
That being said, it will most likely be the power supply in your system causing the problem. They can be replaced fairly easily.
Jul 14, 2008 | Toshiba Computers & Internet
PCVRS620G won't turn on
i feel this is not a big problem. if u hear a beep of ram on beap on boot then ram is ok just short it and check for displaay. check ur cpu socket it may be loose. if u don hear a beep on boot change the ram and ur problem will be solved
Feb 07, 2008 | Sony PCV-RS620G PC Desktop
Stops booting
Did you remove the components that you upgraded, and try adding them back one by one?
Will it give you a POST screen?
Does it Beep at boot time? If it is noisy try moving it to another room.
Describe the original components and then the ones that you upgraded in detail. This will allow us to better troubleshoot the problem.
Dec 02, 2007 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Computers & Internet Logo
David Payne
David Payne
