I plug my mouse in it works a few seconds then stops
I plug into the USB port ,the mouse works for a few seconds then stops ,I take it out plug it in again it works then stops
Try new batteries and another USB port.
Posted on Feb 12, 2012
TampaNative
  • 778 Answers
SOURCE: USB ports not working
Okay, have you tried another USB device to see if the USB mouse you mention isn't the problem? If not, it could be as simple as a dead battery in the mouse or faulty cable.
Posted on Sep 06, 2008
SOURCE: keyboard, mouse and usb ports don't work.
I have a Acer 5100 I am facing the same prolem my USB ports stopped working and then the Keyboard the system boots but i cannot do anything like the password nor can i start in safe mode or go to set up, if somebody can help me sort this problem ,thankyou
Ahmed
Posted on Nov 12, 2008
haayz
  • 197 Answers
SOURCE: mouse pad not working - external mouse works fine,
try to re-intall your mouse pad driver and update your machine's bios.
if still doesn't work then you mouse is faulty and might need to replace.
Posted on Jul 01, 2009
  • 7993 Answers
SOURCE: My laptop touchpad stopped working
Go to Control panel, Classic View. Click the mouse icon. Under TouchPad Tab make sure that the touchpad is enable. Under the Advanced tab you can configure the touchpad further.
Hope it helps.
Posted on Sep 29, 2009
  • 1481 Answers
SOURCE: My Dell Latitude D400 laptop's USB ports stopped
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
Posted on May 10, 2010
Mouse highlights everything
Your left-click button on the mouse sounds like it may be broken. A few things to try before buying a new mouse:
- If it is a wired USB mouse, unplug it from it's USB port. Wait 10 seconds and plug it back in.
- If it is a wireless mouse, unplug the small USB Dongle from it's USB port. Wait 10 seconds and reinsert the Dongle.
- If wireless, check the batteries in the mouse itself.
- Try another mouse. ( If the problem persists with a different mouse, it is a software issue and should be addressed in a new question. )
- Try another USB port. ( If the problem persists while using a different USB port, it is a software issue and should be addressed in a new question. )
Feb 01, 2014 | Computers & Internet
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
I am switching from one wireless optical notebook mouse to another. When I plug the new receiver into my usb port and press the connect button on the receiver, it blinks for a few seconds and then stops...
you might also want to try pressing the conect button on the mouse as well as on the usb... do this at the same time... aslo make shur that your not using the mouse on a flat sheen surface... try using paper or somthing
Oct 30, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a Wacom Bamboo Fun Medium Table with Cordless Pen. I've had it for about 3 months. It's been working great until this week. I notice it disconnects (the light goes out and it stops working). I...
It may be the USB port you're plugging into going bad. Try switching to plugging into a different USB port and see if that fixes the problem. If it doesn't it may be something faulty in the tablet itself and will still be covered by the manufacturer's warrenty. From my experience with Wacom, they're very prompt in fixing or replacing bad tablets.
Sep 17, 2009 | Wacom Bamboo Fun USB Tablet with Cordless...
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
My mouse will suddenly stop moving new battery doesnt help
Is there a resync button on the bottom and on the base station (that is on the end of the usb plug that you plug into your computer)? Press the one on the base station first, then the one on the mouse within a few seconds.
You could also:
Try another set of batteries.
Jul 16, 2009 | Logitech Cordless Mouse
Mouse stops to soon.
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 05, 2008 | GE Wireless Optical Mouse
Microsoft vista and wirless mouse problem
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Jul 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Computers & Internet Logo
393 people viewed this question
David Payne
David Payne
