Question about Radio Communications
What is ground wire attatched to on glass mount antenna
SOURCE: Red Lights
Check your microphone connection. There may be a short in your mic plug. Some radios require a microphone to be connected in order to receive. If you recently changed microphones, be certain it is wired for your particular radio. Hope this helps. Also, do not use radio if this condition still exists as damage will occur.
Posted on Nov 24, 2006
Mechanic688
  • 204 Answers
SOURCE: not receiving properly
Pitcrew, does the noise go away when you screw the pl259 down tight? Find someone talking on a channel and do the PL test again and see if their signal disappears when you screw down the PL. Have you done an SWR test yet? Is this a fairly new antenna? If this problem came into my store, the first thing I'd do would be an swr test, the second would be to test with a volt/ohmeter from the center pin on the PL to the metal stinger to make sure there is a connection.Then check from the trunk mt to the outer ring of the PL for connection. Now, if you check from the center pin to the outer ring of the PL you should not have connection! If you do, the coax has a short in it,,,
Is this mounted on a trunk of a car? Sorry for all the questions, but there are so many different things it could be, and I'm just trying to narrow it down for you. Hope this helps some, let me know,,, Mechanic
Posted on Jan 31, 2008
Shuttle83
  • 1139 Answers
SOURCE: CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
Posted on May 14, 2008
the cb man
  • 7 Answers
SOURCE: I am getting high swr readings on my base station
what i would do is go and buy a real cb antenna mount like a mirror mount and get a peice of sheet metal and screw the mount to the metal and screw that to the roof or side of the house and you should buy a spring that will also help with the swr and if you by the mount you can just screw on a standard pl259 connector
Posted on Apr 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Posted on Aug 17, 2009
How do I install a tram 1191 ******* glass mount antenna
Has the sticky pad been used already? If not just remove it an place against glass an attach other side to glass as well. Making sure all parts have room. If sticky pad is removed or used up you can contact factory about replacement ot try thr rear view mirror glue that is used for those. The antenna works nicely when set up properly
Aug 21, 2014 | Tram 1191 Amateur Dual-Band Glass Mount...
Grounding uhf antenna
First off, using a Ground post driven into the soil is important. The best ground post procedure is to SLANT a 6 or 8 foot rod into the soil at an angle (not directly down). The angle allows for a greater ground surface and is more effective. If a Ground rod is cut off because it cannot be driven deep into the soil; this defeats the need to ground electronic or other devices.
12G wire is OK for an antenna if 8 or 10 are not available. Copper is best, but aluminum will work. The Grounding bock is attached to the mast, usually near where the antenna if affixed to the mast. Simply drill a small hole into the Mast section using the block as your guide. Using a hex driver and small hex screws, tighten the block to the mast. Good contact is necessary, so tighten all attachments. I suggest getting Rubber Boots or Covers to protect the connectors on the block from corrosion. The reason I attach blocks to the mast is to ground the Mast first and Antenna second. Not a critical feature. You may also use petro-jelly to cover the nuts, bolts, and screws to prevent corrosion or binding.
Dec 18, 2013 | Cable Wholesale F-Pin Coax Grounding...
When explaining that an antenna needs to be 'gounded', does this mean that the bracket the antenna is attatched to needs to be actually hard wired to the vehicle frame or when using a magnetic mount...
Hi, my name is John. Welcome to FixYa. Yes, That is not sufficient enough for your antenna. Need any further information let me know. Thanks for choosing FixYa...John
Nov 23, 2010 | Cobra 29 LTD CB Radio
Where is the antenna located on a 1996 lincoln towncar
The antenna is located on the top of the rear glass. There is no external antenna mounted on the 1996 Town Car. If you look at the rear glass, the antenna is the squiggly wires at top.
Feb 15, 2010 | 1996 Lincoln Town Car
Excessive static equally on all chanels on cb
You should always connect the CB directly to the battery as the accessory socket is full of noise. You also should choose a better antenna as these small glass mounts cannot hear signals well and magnify local noise. AM (CBs) radios naturally pick up noise as it is the nature of AM signals. Use your squelch to lesson this but too much can knock out you reception.
Feb 14, 2010 | Cobra Radio Communications
How do I install the power antenna? I have a replacement, and the wiring is there, but I don't see how to mount the part.
PLEASE DON'T FORGET TO RATE!!!!
Removal & Installation
  1. Lower the antenna and remove the luggage compartment trim panel.
  2. Disconnect the lead-in cable from the antenna and ground strap.
  3. Disconnect the antenna motor wires at the connectors and disconnect the control box connectors.
  4. Remove the top mounting nut and stanchion assembly.
  5. Remove the two nuts retaining the antenna bracket assembly to the quarter panel.
  6. Remove the antenna assembly from the vehicle.
Some antennas require a special socket to remove the locknut
Once its loose the nut can be removed by hand. Sometimes it can be twisted off with a needle nose pliers, but that usually ruins the tool
The antenna mounts in the luggage compartment against the support member
The motor and housing sit on a stand that is bolted to the support member
Unplug the antenna lead from the staff tube
Unplug the connector to the motor
Unplug the connector to the relay
Its easier to remove the antennae from the support to gain access to the ground strap screws
To install:
NOTE Correct sequencing for installation is important to prevent water leakage or dimpling of the quarter panel
  1. Connect the antenna cable, power connector and control box connector.
  2. Insert the antenna mast through the quarter panel hole and position bracket on mounting studs in the luggage compartment.
  3. Install the stanchion assembly.
  4. Loosely install the two bracket retaining nuts.
  5. Install the top-mounting nut.
  6. Tighten the bracket retaining nuts.
  7. Install the ground strap.
Nov 19, 2009 | 1990 Lincoln Continental
How do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Nov 04, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
3 prong connection to fusebox using hot wire, neutral wire, and ground wire. I know the hot wire and neutral wire connect to the circuit breaker, but I'm unsure about the grounding connection.
There will be a ground log/screw somewhere in the panel box. The ground wire goes to that.
If you see other bare wires going to a screw in type attatchment that is mounted to the panle box without insulators, that is the ground mount.
Oct 03, 2009 | Dryers
I am getting high swr readings on my base station antenna. It is a 102'' whip and I don't think I have it connected properly. I connected the center copper wire to the antenna but did nothing with the...
Apr 15, 2009 | Radio Shack Radio Communications
2-way radio causing voltage to spike
Hi and welcome to FixYa,
Your described problem indicates that the RF from the Motorola is being received by the electronic regulator of the alternator and is erroneously factored in as sensor/triggers. Simply stated, the RF causes the regulator transistor to conduct more allowing higher voltage output. There could possibly be two ways of addressing the issue: regulator/alternator side and/or the Motorola side. Things that you could try:
  • shunt a reverse protection diode across the output of the alternator to the ground;
  • install filter condensers on all the wires leading to and from the alternator;
  • wire a ground strap (not a ground wire) from the firetruck's - terminal of the battery to the alternator housing;
  • check/improve (lower down) the SWR of the antenna;
  • if you are using a magnetically mounted antenna, replace with a gutter mount or similar mounting brackets;
  • wire a ground strap (not a ground wire) from the antenna mount to the radio to the body of the firetruck to the alternator to the - terminal of the battery.
A ground strap is a flattened braided electrical wire unlike the common stranded auto electrical wire.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Motorola Radio Communications
Radio Communications Logo
21 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
