Question about iLO 3200 32 in. LCD Television
Ilo hdtv black screen
I hooked my ilo tv to a cable box and the screen went black and the repairman said it was a surge has anyone seen this before
SOURCE: ilo 42 in plasma
This must be a Samsung controller inside. Samsung controller have trouble finding if signal is ntsc or pal when tv is turn on before the source. If this is the case, just turn off the tv, start the cablebox and power on the tv again.
Posted on Feb 11, 2007
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: ILO universal remote code
funai Code 0171 worked for me. you can try other funai codes
Posted on Oct 05, 2007
SOURCE: ilo 42 in. hdtv
If it's TiVo code, it's built in to TiVo's IR.
Otherwise please be a little more discriptive in exactly what you are trying to do.
Posted on Oct 25, 2007
Matteh
  • 83 Answers
SOURCE: Ilo plasma
Well, it could have been struck by somthing, have you tried unplugging it from your wall and re plugging it in? If so - it may be just flat out dead
Posted on Nov 30, 2007
How do I hook up my digital cable to my ilo flat screen TV with out a box
It won't work because the tuner from your ilo TV will not be able to decode the digital signal from the cable company even if your TV has a digital tuner. The digital tuner on your TV will only decode over the air signals.
You will still need the digital cable box from the cable company.
Aug 03, 2015 | iLO Televison & Video
My ilo hdtv doesn't have a cable hook up
Going to have to connect (no coax fitting means it is a monitor with no tuner) via one of the rear audio/video inputs with a box that has those outputs on it.
HD is almost always connected in this way.
May 02, 2012 | iLO IWT3206 TV
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
Ilo picture problem
turn off the closed caption Sounds like it's in text mode
good luck
Sue, Hitone tv, Baldwin NY
Feb 14, 2008 | iLO 2600 Television
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Oct 27, 2007 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
90 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
