Question about Bosch Washing Machines
Logixx vario perfect 8 ,F 57 code
Selam,ayn? sorun benim makinem de de oldu.F 57 hata kodu belirdi.Önce deterjan gözünden 1 litre kadar s?cak su koydum ve tekrar çal??t?rd?m.sorun halloldu.(first ,hot water give the machine( up the case) and start the machine.Then ,perfect :))
heatman101
  • 43501 Answers
SOURCE: Hot water is a small
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenm Elite HE3 frontload Keeps giving us the F11 Code & it stops
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: 1 yr old machine, not filling w/ water. Starts,
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Posted on Sep 19, 2010
nadirsalim
  • 185 Answers
SOURCE: selam.elektrik kesiminde E7 diye hata
1.Memory back-up battery dead
2.Disk Failure
However, as those are typical errors, there should be another code along with E7.
Good luck
Posted on Nov 28, 2010
richroth
  • 9472 Answers
SOURCE: la maquinqa ase todos sus funcionamientos y
Necesito saber lo que la marca y el n?mero de modelo es de su m?quina yexactamente cu?l es el problema con la m?quina.
Posted on Dec 17, 2010
Fault code edc 00637-03 on M.A.N.410
Man tga 410 hata kodu 00637-03 nedir bu ? Yard?mc? olur musunuz ?
Nov 10, 2012 | Cars & Trucks
I have a Bosch Logixx 8 Vario perfect washing machine. Its only a few months old. My problem is that the conditioner is still in the drawer after the wash is finished. What do I do
Bosch Logixx 8 Vario problem is that the conditioner is still in the drawer after the wash is finished This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Aug 17, 2011 | Audiovox Bosch 718 World Cellular Phone
Selam arkadaşlar benim yzf 600r thundercat motorsikletim var sente ayarında bir sorun var nasıl senteye alabilirim yardımcı olursanız sevinirim...
E?er hi? de?il Yamaha , umutsuzluk i?in sat?n ilk ve en iyi arac? bulamazsan?z Merhaba , Anonymous Bu senaryo i?in size ba?ka bir indirebilirsiniz sadece 10 $ i?in , servis / sahipleri k?lavuzu gerekir. Sorununuza ve a?a??daki linklere t?klay?n?z gerekecektir de?erli "?CRETS?Z" indirmeleri hakk?nda daha fazla bilgi i?in . ?yi ?anslar ve g?zel bir g?n var.
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
prody71 html Performance Products YZF600 Thunder Cat
Yamaha YZF 600 R6 06
Jan 09, 2011 | Yamaha YZF 600 R thunder cat Motorcycles
Selam.elektrik kesiminde E7 diye hata veriyo..makinan?n hiç bir dü?meside çal??m?yo..lütfen yard?mc? olursan?z sevinirim..bilgilerinize..
2.Disk Failure
Good luck
Nov 28, 2010 | Sharp AR-5320 Black and White Copier
1112 cebim var,pilini
Selam
belki telefonunuzu azaltilabilmektedir telefonunuz aç?k ve telefonunuzun ?arj pin temiz .. o arayüzü, mikrofon kulakl?k ve ?arj pin ba?lant?l? oldu?unu ... iyi handsfree telefon hala fixya güvendi?in için te?ekkür .. azaltilabilmektedir olup olmad???n? test etmek için kullan?n ....
Jun 18, 2010 | Nokia 1112 Cellular Phone
Error code 0203
This is a mechanical error. The mechanism is stuck and can not reset to a known condition. Look to see if a CD has slipped nad try to get it back in place. If that is not the case, it will need service as the mechanism is now out of timing.
Dan
Mar 26, 2008 | Sharp CD-BA2600 CD Shelf System
Philips mms460 5.1 surround sound speakers
Its better to change your probes because it has been get damaged...
thankyou...
Jan 02, 2008 | Philips MMS 460 Computer Speakers
Washing Machines Logo
884 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
