Question about Gary Fisher Presidio
How do I adjust my hand brakes? - Gary Fisher Presidio
    Problem Solver:
  • 13 Answers
There is an adjusting screw on the handle and one at the bottom of the brake cable. Squeeze the brakes by hand tight on the tire and adjust the scews.
Posted on Feb 12, 2012
How do i adjust hand break new shoes fitted on a smart for two hand break lever is all the way uo ?
Adjusting the Hand Brake is quite easy
At the bottom of the Hand Brake Lever , you will see the cable with like nuts (teeth) on the cable locked by the lock on the lever it self, you will need to open the lock , take the cable off the lock , drop the handle down and put the cable back on the lever and lock it.
That is how the hand brake is adjusted on the Smart car 2002 model
Mar 14, 2016 | Smart Cars & Trucks
How do I adjust parking brake
If Disc brakes jack up wheels , make sure the cable is not binding or frozen , pull hand leaver on three clicks, adjust cable till brakes just start to bind, release hand brake and check the wheels are free to turn. Drum brake check cables are free, back off cable till slack, check lining to drum adjusters are free and adjust if need be, pull hand brake on three clicks, adjust cable so brakes just start to bind release hand brake and make sure the wheels are free to turn ,
May 27, 2015 | Cars & Trucks
Why wont a97 f350 parking brake adjust when backing up and applying brakes
self adjusting action of the brakes only applies to the foot brake action for the shoes. hand brake is adjusted by cable adjustment or cable at the hand brake lever adjustment
Feb 27, 2015 | Cars & Trucks
Toyota 2005 hand brake not working
Is the hand brake really easy to pull??? You may have to adjust your hand brake cable. I found a video on how to adjust the cable.
Hope this is helpful :-)
-Scott Handbrake Adjust Toyota Corolla
Feb 14, 2015 | Toyota Camry Cars & Trucks
How do I fixed if my car hand brake stuck 2001 toyota coralla manual
There are several things that can make a hand brake stick on. It possible the cable attached to the leaver has come off it guide. There is a cable running from each rear wheel to the handbrake leaver , a inner cable running through a outer housing , chick that the inner cable is free to move back and forward . if all the cables are free to slide adjust the rear brakes and hand brake as instructions . Slacken off the hand brake cable adjustment. Jack up the rear wheals and adjust the brake shoes till the brakes lock, then back off till the wheels are free to turn. Then pull the hand brake leaver on two clicks and adjust the hand brake cable till the rear wheels just start to bind, release the hand brake leaver and check the wheels are free to turn.
Nov 27, 2014 | 2001 Toyota Corolla
How do I adjust the handbrake on 2003 Kia Carnival
I have not checked a kia carnival but worked on most kia cars. There are two hand brake adjustments. One is at the hand brake lever. open up the hand brake cover and look for the nut adjuster where the end of the hand brake cable is attached to. Tighten up that nut until you find a comfortable hand brake position and the brakes locks.
the other adjustment is found at the rear brake drums. you have to remove the tires and tighten the adjusting nut behind the brake plates. there is a small hole, usually covered with a rubberized plug. remove that plug and adjust the brake with a flat screwdriver.
Oct 26, 2014 | Kia Carnival Cars & Trucks
Holden commodore problemsi have a vy commodore brakes just re-knewed but carnt see where to adjust hand break cable mcan u help
most times the hand brake top screws down to adjust the brake but there is normally an adjustment under car where the cables from the rear wheels join the single cable going to the hand brake If the hand brake top has been screwed down all the way loosen it up al the way before adjusting anything
Aug 20, 2014 | Cars & Trucks
89 gta with 4 wheel disk breaks and the e break does not hold at all. both caliber have been changed and adjusted the small screws on them so the pads are just touching the rotors. the cable has been...
You need to adjust your hand brake (e-brake) you will usually find the adjustment bolt under the console between the front seats, or under the dash, depending on the type of hand brake you have. it looks like two cables going to a crossbar then single cable from the crossbar to the hand brake. at the end of the cross bar will be a nut that you use to adjust the hand brake (make sure you hand brake is off before adjusting it)
Nov 08, 2010 | 1989 Pontiac Firebird
Tightening the handbrake
the first thing to do is to slacken the handbrake adjuster on the lever off completely.then if you have rear drum brakes remove the drums and make sure that the handbrake levers on the shoes are not siezed and are returning to the stops plus that the auto adjusters are not siezed if not free them off so they are using wd40 or whatever and the linings/drums are ok then reasemble and pump the brake pedal a few times to let the auto adjusters work then readjust the lever to about 5 to 7 clicks if you have got rear discs then one off the rear calipers may have siezed or both handbrake cables should also be checked for being siezed
Dec 23, 2017 | 1999 Nissan Maxima
How to adjust the parking brake on 2007 Honda Accord LX?
there is an adjusting screw atached to the hand brake cable located near the hand brake it self but before i do that i would check and replace the rear padds first and replace if needed! that could be the reason why your hand brake needs adjustment???
Dec 15, 2008 | Honda Accord Cars & Trucks
Gary Fisher Presidio Logo
102 people viewed this question
Top Gary Fisher Cycling Experts
dante
Andrew Taylor
Andrew Taylor
Are you a Gary Fisher Cycling Expert? Answer questions, earn points and help others
