Question about Frymaster Dean SR42G Deep Fryer
Deansr42 flame back flowing around orvice
  • 430 Answers
The flame in my noritz tankless water heater turns off when I lower the pressure of water flowing from the faucet (however when the flow of water was at high pressure the flame never turned off). This also...
has this heater always acted like this? if so
you need to supply heater with the right water pressure or flow
try cutting back by turning inlet valve off to restrict flow or restrict flow on hot end. hope it works it did on mine
Dec 30, 2014 | Water Heaters
Caravan fridge wont ignite when on gas
does fridge work on 12 volt? If yes, 1 check and make sure you have 'good' gas. Next you can check the orvice/ignition area for any forgien matter, cobb web/spider webs must be removed. You can blow out that area with nan air hose. wear safety glasses!!! follow instruction for lighting. If you still do not have any flame you mave have a bad pilot valve.
Feb 18, 2012 | Electrolux Refrigerators
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
Want to convert heater from natual gas to lpg are jets available for this conversion.heater model no reh210ec thankyou
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Jul 05, 2010 | Heating & Cooling
Grill tank full but very low flame, where could it be plugged. Is it the regulator?
I could be a plugged orifice or the regulator. The regulator is an easy place to start.
Jan 09, 2010 | Weber Baby Q Grill
LP Ruud furnace achiever 90+. Strange problem.
Sounds like two problems. Not enough combustion air or a defective high temperature limit switch. You enclosure may not be getting enough outside air to properly sustain combustion. If the unit has a rollout thermostat it may be defective and stopping everything.
Oct 10, 2009 | Heating & Cooling
GAS FLOW IS TO HIGH PILOT GOES OUT EXCESS GAS FLAME ON TAPPEN FU
Hi this could be a gas leak on the pilot i would get this checked out
Mar 17, 2009 | Tappan TGF320 Gas Kitchen Range
Flame does not seem hot enough - too much yellow flame.
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Jan 05, 2009 | Kenmore 63942 Dryer
I have a 425 gas tankless water heater. In 3 years in the winter (and sometimes warmer weather) I have never gotten a hot shower. The water starts out warm, and in the middle of the shower changes to...
Is it a bosch.What is the exact model number.I have one and i love it once you get it set.It seems that there are two flame levels low water flow and high water flow.If your shower has a water saving restricter in it it may not flow enough to let the flame get too high.So i would remove it.If there is a knob on the front turn it all the way clockwise and try it.There is also a screw on the inside that you can adjust the low water flow flame , it the brass one with a locking screw on it.Your manual should show it.If you need to adjust it turn on your shower and go check the flame and use that screw to increase the flame.Hope this helps and let me know how that works
Nov 29, 2008 | Heating & Cooling
Whirlpool gas dryer model # LGR4634JQ1. The dryer has an initial flame when first started up, but after about 15 seconds the flame goes out and the dryer remains cool.
The flame sensor is probably bad. This is located on the side of the tube the flame is in. Has two wires going to it. Try to short it out and see if the flame stays lit. UNDER NO CIRCUMSTANCES OPERATE THIS DRYER WITH CLOTHES IN IT WITHOUT THE FLAME SENSOR IN PLACE!!!!! The other problem might be air flow. If the duct is blocked the flame will trigger the high limit switch. Take the hose off the back of the dryer and turn it on. There should be a lot of air flow. If there is and the flame stays on the duct hose or outlet is clogged.
Jun 19, 2008 | Whirlpool Dryers
Frymaster Dean SR42G Deep Fryer Logo
67 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
