Question about Compaq Presario 5000 PC Desktop
Hard drive fan stop working computer stop, yes I have power but but,computer will not tyrn on PC will not power up when I woke up this morning and went to use it the green light on the front was flashing as if it was in standby then when i went to move the mouse the green light continued to flash. Then i checked the back of the computer and the green light was on on the back of the computer. There is a fan and it is not moving. Tried to unhook the main power supply and reconnect and now the green light on the front won't come on at all. There is no response from the power button on the front but the green light on the back of the PC is still on........????? My model number is the Compaq Presario SR 1907 CL it was not listed on the drop down menu underneath here
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sounds like the power supply needs to be replaced..
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Disconnect the pc, remove the side panel. Use a bright flash light or directional light, carefully remove the cooling fan from the mother board. If there is signifiant dust built up on the fins and inside the fan, I would buy a new fan to replace it. But before buying the fan...have a good, close look at the mother board. If you can see what looks like heat damage then take the pc in to the shop.
Posted on Sep 05, 2009
  • 749 Answers
Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
  1. Disconnect everything from the computer, including the power cord.
  2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
  3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch Hard drive fan stop working computer stop - c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
  4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
  5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
  6. Remove all attached devices except for keyboard, mouse, and monitor.
  7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
  8. Check the power switch:
    1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
      • If the button sticks, it should be replaced or serviced.
      • If the power button does not stick and appears to be functioning, continue using these steps.
    2. With the power cord disconnected, remove the case or side panel.
    3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
    5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
Posted on Oct 24, 2008
  • Jeff Strader
    Jeff Strader Oct 24, 2008
    Find the defective part:
    1. With the power cord disconnected, remove the case or side panel.
    2. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference.
    3. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
      • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
      • If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
      • If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
      NOTE:
      If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement. If the power supply was damaged due to power outage or storm, this may not be covered under the "act of nature" policy in the warranty statement. Refer to the warranty statement that came with your computer for more information.
Gateway nv52 laptop cays corrupt registry stuck in recover mode
start computer and lunch startup repeir. you see windows is loding files and you see blue screen read and click next computer will start now
May 31, 2013 | Gateway Computers & Internet
Dell optiplex gx 620 powere went out last night and this morning it won't turn on. The only light I see is on the motherboard and its solid yellow
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
Nov 30, 2011 | Dell OptiPlex GX620 PC Desktop
N610C computer-fan evidently stopped working. DVD-Rom works, Display does not power up nor the Hard drive. Hard drive works on other commputers. Battery light does not show charge, but DMM confirms power...
If the fan stopped working then..none of the things will work because there is no cooling system for the processor...take this computer to a local tech..or if you cacn do..upside down the laptop at the bottom remove the cover(small partitions) check for the dust there...clean that area with a vacum cleaner..
Aug 18, 2011 | Compaq Evo N610C Notebook
Power button blinking red on gateway profile 4...monitor appears to be on, fan is operating, can hear drive starting but computer will not boot up. Checked power to hard drive and ribbon cables, memory,...
1.Check your power supply by using an Analog Volt Meter, you should check if the power supplied by your power supply is stable,
2.Check your ram if it is faulty. try to clean the lids of the ram using an eraser. If still your computer doesnt work, you should find a spare RAM and test if your RAM is working properly.
3.If you dont have any problems with your RAM, you should try unplugging external PCI cards, AGP Cards, on your motherboard and use the internal devices instead, like built in VGA, sound card, Network Interface Card,just to check if there are no faulty devices which stopped your computer from starting.
Hope this will helped you out mate :)
Jan 02, 2010 | Gateway Profile 4 XLb PC Desktop
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
The hard drive does not have a fan unless you put one on it. The hard drive is inside the computer and had a company name on it such as Maxtor, Seagate, Toshiba etc.
Did you unplug the fan that stopped working? If the fan is your processor fan, it might have burned up your computer. I have seen the entire motherboard go bad on a computer, just because a fan stopped working.
What make and model computer is it? If it is a laptop, it might be damaged beyond repair. Let me know more information, and I will keep trying to help you get the problem resolved.
Jun 08, 2008 | Compaq Presario SR1000T (568657) PC...
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Drive Not Ready
typical of external drives overheating.
i sell external case with fan at my store.
Nov 03, 2007 | Fantom Titanium Hard Drive
Compaq Presario 5000 PC Desktop Logo
349 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
