Can not light my valor br 627 gas fire - Heating & Cooling
4 Suggested Answers
  • 4736 Answers
SOURCE: Can I fit a Valor
Just for information ... whether you're doing it as a 'B' -Vent (Straight up) or a Direct Vent (Straight out the back), it requires an appropriately sized Coaxial Vent Pipe. A Coaxial Vent Pipe is a pipe within a pipe, That has an air space in between the inner and outer pipe. Of course it will also need the appropriate termination cover.
For for technical advice on proper venting go to http://www.valorfireplaces.com
Posted on Feb 08, 2011
  • 4736 Answers
SOURCE: Initial problem was that fire
First, have you changed the battery in the ignition system? If you haven't this could be causing your ignition problem. In addition, the Thermocouple may need to be replaced to solve the problem of the burner flames going of on their own. That's assuming the pilot light is also going out when the burners go out. It would also be wise to check the vent pipe to make sure it's not obstructed in any way. As this also, could cause the flames to go out. Because there is a Safety Overload Switch, that automatically shuts the burner off is there is a gas and heat buildup/backup in the firebox.
As far as replacing the Thermocouple is concerned, this unit uses the same type of stand-alone Thermocouple, as the older DESA Vent-free gas log sets and fireplaces used. It's held in place with a saddle strap mounting and is fairly easy to replace.
These fireplaces are made in the UK and therefore, are more complicated to install, diagnose a problem and then solve it, than those made in the U.S.
Hope this has helped get you headed in the right direction.
Posted on Feb 25, 2011
  • 4736 Answers
SOURCE: i have a valor dream
The coals have either shifted or were installed improperly. They are causing flame impingement, which causes soot. If you have your Owners Manual consult that, for the proper placement of the coals.
Hope this helps you to solve the problem, Danny.
Posted on Apr 17, 2011
Valor nevada deluxe 2 gas wall heater instructions
We have two Valor Nevada2 Deluxe outside wall mounted natural gas fire heaters ( with flues ). After years of use, they require being replaced. We want similar. Please recommend the best type.
Thank you."
Jan 06, 2012 | Heating & Cooling
Can I get Manufacturers instructions for valor dream gas fire G.C. 32-310-91
You can view the fire opening requirements and product information on valor gas fires
Alternatively you can download a PDF of the complete manufacturers instructions here
Feb 08, 2011 | Valor Toys
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
www.valor.co.uk
alternatively new Valor Gas Fires
Jan 02, 2011 | Valor Toys
The flame effect on my valor 846 electric fire is not coming on, i think it is an led that is not lighting up. how do you change the led and where can i get one. thanks Gerald
The LED is on a circuit board located inside the fire. The board itself needs to be replaced.
The part would be available from valor spares under your warranty.
The number for valor spares can be found at Valor fires
Dec 26, 2010 | Stoves Heating & Cooling
Valor blenheim gas fire correct coal settings
Hi go to www,valor.co.uk you and request manuals on line with the coal seting in
Mar 08, 2010 | Goodman GMS90703BXA Heater
I have a valor hone flame gas fire. It is quite old now and I believe the ignition switch is faulty. Does this fire have a self generating ingier or ir there a battery ?
I believe the valor is self generating. Ours is also not working and we need to replace it. Any ideas where to purchase one?
Feb 10, 2010 | Valor Toys
How to arrange the gas fire pebbles for a valor soraya gas fire. My little boy has messed around with the pebbles and ive noticed that the pebbles are lettered and when i initially installed the fire, the...
the user guide can be download here:
http://www.partsarena.co.uk/baxi/System/DATA/Dx/DS1/user/4332/U14-4332/U14-4332.htm#zfuelbedrefittingceramicpebbles
Jan 07, 2010 | Valor Toys
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
