Question about Denon Audio Players & Recorders
Remote uverse
Trying to program the uverse remote to control the receiver
2 Suggested Answers
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    I have the rca remote programed to the phillips tv. now i need to program it to the at&t uverse box.
    There is no set-up code to AT&T Uverse box, with RCA remote control. You have to select an other remote control for this box.
    Jun 07, 2015 | RCA Televison & Video
    How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
    The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
    These are all the different Onkyo Receiver codes:
    Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
    This is how to reprogram the S10 style of Uverse remote:
    http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
    Dec 22, 2014 | Onkyo Audio Players & Recorders
    My Tv is Craig model CLC503. My AT&T Uverse remote will not power on or off the TV.
    Access the help section of the menu on your uverse connected TV. Select the option "Remote Control Setup". Select your style of remote and select the type of device that you want to program your remote to and then just simply follow the instructions provided on-screen.
    Mar 17, 2014 | AT&T UVerse
    I need the AT&T UVerse remote code for my samsung blue-ray player BD-D5700
    Feb 01, 2014 | AT&T UVerse
    Universal remote mx 980
    HI Julia,
    I have a link for you regarding your issue programming your other remote to your att STB. Hope it helps
    Search Results for program other remote to my uverse
    Apr 30, 2013 | AT&T UVerse
    Programming AT&T Uverse Universal Remote COntrol
    Hi Ted,
    You may want to visit this link for your issue. Please make sure you are logged in first for the best results for programming your remote.
    Search Results for program other remote to my uverse .
    Mar 05, 2013 | AT&T UVerse
    Trying to program my At&t Uverse remote to my
    Power on the device
    Sep 05, 2009 | Sherwood RX-4109
    Att uverse remote won't turn on yamaha reciever
    Do an automatic search for your code.
    1. Turn on the device you wish to program
    2. Point the remote control at the device
    3. Press and hold the mode key (i.e. tv, dvd or aux) you want to program
    4. Without releasing the selected mode key, press and hold the OK key simultaneously
    5. Release both the mode key and the OK key -All the modes keys will flash twice indicating programming mode
    6. Enter 922 by pressing the number keys on the remote control -The selected mode key will flash twice indicating correct entry (for anything other than AUX go to step 7, for the AUX mode searching only, press and release the play key then press 1 for VCR 2 for Receiver/Tuner 3 for Amplifier or 4 for Home Theater In The Box (HTIB) - The AUX mode keys will flash twice indicating correct entry)
    7. Press and release the PLAY key, every time you do this, autoserach will try a different code, continue to do this until your device turns off. (if you weren't paying attention and you miss it, the REW key can be used to go back through the codes one at a time, and the ff key can be utilized to move forward through the codes one at a time.)
    8. To save the code press the ENTER key (below the number 9) then press the exit to return to normal operations. (the selected mode key should flash three times
    9. Turn you device on by selecting the appropriate mode and power.
    Jan 19, 2009 | Yamaha HTR-5940 Receiver
    Need yamaha codes to program into uverse tv ir remote
    (I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
    Jan 09, 2009 | Yamaha RX-V800 Receiver
    I need ATT uverse remote control code for Onkyo AV rec TXSR304
    hi just a tip! try to program your remote to control both your tv and the cable box both at the same time so when you try to adjust the volume automatically both tv and the cable box will respond. you can actually call uverse for that so that they can assist you on programming your remote to your tv and cable box. hope this would help goodluck!!!
    Jan 04, 2009 | Durabrand DWT1304 13" TV
    14 people viewed this question
    Top Denon Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
