Question about RCA L40FHD41 40. in HDTV
Cyles channels repeatedly and it puts the volume all the way up
  • REBECCA GRAY Apr 07, 2012
    anyone have any answers why this does happen?
  • 430 Answers
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
The TV remote is not working and when i do it manually the following problems i face when i put on the TV, it opens with VIDEO ONE, one more press then it goes to DVD One more press then the channel...
Try to use another remote - if it's the same then the problem is with the control processor of the tv - you are going to have it replaced at great cost.
Aug 30, 2010 | Televison & Video
My kv34hs510 will not power up and the standby light flashes 6 times and then repeats.What is wrong? Ron....
There is a power issue,tv goes into standby (safety) mode. For self-diagnostics, press Display,channel,5,volume - minus not plus,then press power. You have no horizontal output,check IC206,C516,C515....for service mode press Display,Channel,5,volume + plus,then power,press8,then enter......hope this helps....
Mar 08, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
How do you turn ringer on and off on a uniden exi8560 cordless 5.8ghz
hello. To turn the ringer off on that phone you need to get into the menu. The way you get into the menu is press and hold the menu/cid button for 2 seconds. Then press the arrow down button until you highlight the ringer volume. once the ringer volume is highlighted, press the select/channel button. that will rotate you through the 3 available volume levels. High, low and off. as you are pressing the select/channel button the handset sounds a sample of the volume level. when you hear the volume level you want simply press end and that will store your volume to the off position. to turn it back on, just repeat the above steps but select the proper volume level you want and then hit end. I hope this helps.. Don;t forget to rate me. thanks !
Sep 07, 2009 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
SOLID AUDIO F-45 4CH 900W ONE OF THE FRONT CHANNELS ...
HI DUDE TRY TO CONNECT ONLY 2 PC OF UR 6x9 AT FRONT CHANNEL TRY IT OUT COZ IT MAYBE THE DONT HAVE MUCH POWER TO HIT VOLUME OR ELSE TAKE OUT UR SUB CONNECT TO FRONT CHANNEL OR CHECK UR SUB VOLUME .,...
Apr 01, 2009 | Solid Audio Formula Series F45 4-Channel...
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
RCA L40FHD41 40. in HDTV Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
