Question about Kenmore 62602 Electric Dryer
Replacing fuse on kenmore dryer model 78731 - Kenmore 62602 Electric Dryer
2 Suggested Answers
  • 161 Answers
SOURCE: Kenmore Dryer Model 110.73952102
Yes, It is usually on the heating element tube. Don't just replace the fuse. You must find out what caused it to blow. You probablly have restricted air flow . Usually this is a clogged duct pipe or outside vent. This can also be caused by trying to operate the dryer with the door open. Before replacing the fuse, take the duct off the back of the dryer. Clean out what lint you can , turn on the dryer and see if you get good air flow. Next check the vent pipe for clogging and check the outside damper. DO NOT USE FLEXIBLE PLACTIC DUCT PIPE. It is a fire hazard and almost always clogs up fast. Another possible solution is that if it's an electric dryer, If the element burns out it can short out against the frame and cause it to overheat.
Posted on Jun 29, 2008
I need to replacement fuse for Kenmore electric dryer. model number 110.62212101
Sears Parts Direct lists all of the parts for the 110.62212101 here: www.searspartsdirect.com/model-number/11062212101/0582/0151200.html . If you need the dryer thermal fuse (3392519), that is part 9 on the Bulkhead diagram. The direct link to the part is http://www.searspartsdirect.com/part-number/3392519/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE . They also sell thermal fuse kit, http://www.searspartsdirect.com/part-number/3977393/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE .
Other vendors will have the part since the dryer is made by Whirlpool. Whirlpool used the parts in many models.
I hope this helps.
May 16, 2017 | Kenmore Dryers
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
How do I replace the fuse in the dryer for stackable Kenmore model 417.98702891
This is an excellent source. Click on the link
http://www.repairclinic.com/Shop-For-Parts/a17b6d632276-x6d6f64656c/Model-Model-41798702891-Kenmore-Washer-Dryer-Combo-Parts
Jan 18, 2015 | Kenmore Washing Machines
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
How do you replace the thermal fuse?
The kenmore fuse mounts on the dryer blower housing.On a gas model this fuse when blown will allow the dryer to run however on an electric model this fuse will kill the dryer. The maytag fuse mounts on the right hand side of the heater. Note: the 2 fuses that come in the kit are rated for gas or electric dryers. When this fuse blows the dryer will be dead. The GE fuse mounts in the rear on the heater element pan. When this fuse blows the dryer will continue to run but their will be no heat. Dryer duct fuses are used on various brands of dryers as a back up they usually come in pairs with one mounted on the heater and another near the blower. The kenmore hi limit will kill the heater element but not kill the machine, it mounts on top of the heater housing. The bottom limit comes with it, always replace them both when repairing the dryer.
Dec 22, 2009 | Dryers
Kenmore gas dryer does not get hot
hi. thanks for the question .check the thermal fuse, at the back inside the dryer. remove back panel .thermal fuse is on the air duct , a small piece of plastic with 2 blue wires to it. replace the fuse also clean all venting .thanks the appliance doc
Oct 05, 2008 | Kenmore Dryers
Kenmore dryer model #11071804000
thay can go bad soon but ck the thermo fuse on the dryer its a white fuse on inside dryer that will fix it 98% time
Feb 25, 2008 | Kenmore 63942 Dryer
Gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
Sep 13, 2007 | Kenmore 93042 Gas Dryer
Kenmore 62602 Electric Dryer Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
