THERMOKING SB3 MANUAL - Heating & Cooling
It is a thermoking refrigeration unit on a commercial truck trailer as in 18 wheeler not a car or pick up ! And today I noticed some motor oil in the coolant
Its a gasket leak either head or intake manifold or a cracked or warped head how hot did it get.
Any other problem that could cause this would be a rebuild of the engine .
Jun 30, 2016 | Miscellaneous
Thermoking APU. Why doesn't it work?
Sounds like no power to it. Check the breaker or fuse. Connector may have vibrated loose. If it has a wireless remote, change the batteries in the remote. Good luck.
Sep 15, 2015 | Heating & Cooling
How to clear "04" fault code on a thermoking sb 210?
It's been a while since I worked on Thermokings. But all I worked on, when the problem was fixed, the code would automatically be gone.
Aug 14, 2015 | Cars & Trucks
Thermoking v-550max l want to know how to off the maintenance symbol.
On the task bar on the bottom right u will see the printer icon or the maintenance icon , just right click on it and say hide the icon and it will turn off the maintenance symbol.
Nov 21, 2014 | Computers & Internet
How do I open a Klipsch SB3 soundbar to repair it?
The front bezel may be a tight friction fit (to prevent rattles). Gentle application of a putty knife may pry it loose. I know Vizio uses such an arrangement so others could be similar.
Sep 13, 2014 | Computers & Internet
My thermoking 41-7784 power inverter will not turn on after pressing power button. What do I need to check next...fuses?
Look for the red reset button. Think there are two of them on these units. Could be wrong on that but do seem to recall that they have a reset button on the unit someplace. And check the fuse panel for blown fuses.
Aug 19, 2014 | Televison & Video
Problem GR3630-SB3 Raidon
If your data is get corrupted and you want to backup or restore it then............
try this link..................
http://www.raidon.com.tw/RAIDON2013/enweb/en_product_web/en_safetank/en_GR3630_SB3.html
May 30, 2014 | Misc - MFG GR3630-SB3 Raidon /Esata Usb...
Where can i find a wiring diagram for a Thermoking refridgeration trailer, model number 709662
I have had good success finding very appliances info from appliancesfactoryparts.com
Jul 12, 2009 | Refrigerators
I cannot find a wiring diagram for my thermo-king refrigeration unit
Try contacting them directly. I am sure that they would be happy to replace the original one.
http://www.thermoking.com/genuineparts/
Jul 03, 2008 | Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
