VHS - When I hit eject, unit turns off
I have a Sonic Blue DVR4300. When I try to eject a VHS tape, the unit turns off. Any suggestions?
Thanks.....
    President:
  • 4,402 Answers
Sounds like the mech is out of alignment
Posted on Oct 24, 2008
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
My daughter just had a problem with her Philips tv. It has a built-in vhs player on it, and when she put in a tape, the tv started turning off. I turned it on and got a blue screen that says 't-eject'. I...
It is possible that the Tape mechanism is struck and so is shutting off the power to the unit. Since the power is shared it is possible that the cut off to the set is due to the error in the VHS player.
So in this case you will need to remove the VCR and get the entangled or the stuck up cassette from the player so as to reset the error. Also if there is a mechanical issue to the player must be checked.
Mar 18, 2011 | Televison & Video
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
Tape stuck.
check the tip in my profile
May 19, 2009 | RCA VR651HF VHS VCR
Tape ejection malfunction
The problem may very well be a slipping spool idler that does not tension the tape properly when trying to eject. Try cleaning the rubber friction surfaces or replacing the part....accordianman
Feb 15, 2008 | Sylvania 2870LV VHS VCR
Copying vhs to DVD
unfortunly this model of dvd vhs combo cant record vhs to dvd it can only copy tv to vhs sorry.
Dec 21, 2007 | GoVideo DVR4300 DVD Player/VCR
Vcr jams on eject
What do you mean 'Tape crunches" Do you mean that there is tape slack, which then crunches when Tape is lifted during Eject? If that is the case, then the Supply Reel Roller Brake is bad. it is a Felt Pad, which needs replacing. If the entire eject operation is wonky, or if it's timing is bad, then I suspect that One of the eject Gears (On either side of the Mechanism) is damaged and needs to be replaced. One question, i assume that you are able to eject the Tape eventually, and so - Does the Tape Load into the VCR properly, when you insert it into the machine? This will help me in giving you a better diagnosis.
Mar 13, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Tape stuck in VCR, won't eject.
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod. good luck.
Jan 24, 2007 | Emerson EWV601 S-VHS VCR
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
