Device Manager can't find it any moe after MagicDisc was installed.
SOURCE: I have a slimtype dvd a ds8a2s a ata device that I
From your description I understand that the DVD drive is not working and you have code 10 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
SOURCE: Drive needed for my dvd drive(Slimtype DVD A DS8A1H ATA Device)
Here is a link to all your drivers you can try reinstalling it from here, click here for page. hope this helps
SOURCE: I have Slimtype DVD A DS8A2S ATA Device and
If you don't have a disk for the drive you'll need to go to the manufactures web site and download the proper driver for the drive. You then need to install the driver according to the manufactures instruction, after that windows should be able to load your driver.
SOURCE: Slimtype DVD a Ds8a1p Ata Device Driver NOT FOUND
Go into your BIOS and see if the drive is recognized in there. If its not, then you'll need to turn off the laptop. Take out the drive from the system and then put the drive back into the system. Now go back into the BIOS and see if its recognized in there. If it is still not recognized then the drive is bad and would need to be replaced.
If the drive is recognized then go into windows into the device manager and see if the drive is there. If its not recognized properly then that means you might either have spyware or a virus on the computer. You can also try replacing the drive as well to make sure its not a drive problem.
1.Click on Start.
2.In Start Search or Run type devmgmt.msc and then hit enter.
3.This would open the Device Manager Window.
4.Now locate something which reads as Cd/DVD , there would be a + sign next to it,
5.Click on the +Sign next to it and down below locate the driver responsible for the funtioning of the cd & dvd.
6.Now right click on the driver and then click on Uninstall.
7.Now locate an option right at the top which reads as ACTIONS.
8.Click on Actions and then click on Scan for Hardware Changes.
9.Close the Device Maneger Window.
10.Click on Start and in Start Search type Regedit and then click Enter.
11.This would open the Registry Editor Window.
12.Locate an option which reads as HKEY_LOCAL_MACHINE
13.Click on the +Sign next to it.
14.Now locate another option which reads as SYSTEM.
15.Click on the +Sign next to SYSTEM.
16.Now Locate another option which reads as Current Control Set.
17.Click on the +Sign next to it.
18.Now locate another option which reads as CONTROL.
19.Click on the +Sign next to it.
20.Locate an option reading as CLASS.
21.Click on the +Sign next to it.
22.Now we would find a lot of keys..
23.Locate a key which reads as 4D36E965
24.Click on the Key and then look right at the right top corner of the screen and locate Upper Filters and Lower Filters.
25.Right click on Upper Filter and then click on Delete.
26.Do the same if you get Lower Filters as well.
27.CLose the registry and restart the computer to check rthe funtionality of the Drive.
I am sharing a screenshot of how filters look in registry..
http://filedb.experts-exchange.com/incoming/2008/06_w26/35425/Regedit-DVD.JPG
Hope this works.
Plz rate if helpful
Regards
Ken
