Question about Drills
Keyless chuck has bit stuck in it
Chuck won't open to release drill bit
  • 3 Answers
Use some kind of lube like liquid wrench or wd40 and let it set for a bit. Then tap it with anything like a wrench, hammer, etc.
Posted on Feb 12, 2012
  • 74 Answers
SOURCE: Keyless Chick will not Release - Hitachi DS18DMR
It's best not to use the drill power and your hand to try and release. Or tighten for that matter.
Set the drill down, and try using both hands on the clutch.
If that don't work, try using vise-grips or channel locks.
If that don't work, whip out of the WD-40 and let soak and then try again.
Posted on Feb 10, 2009
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 583 Answers
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Posted on Aug 18, 2009
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Milwaukee1/2 magnum hammer drill keyless chuck stuck closed
yes call 1-800-sawdust that's the Milwaukee factory number. They can tell you what the spindle and thread sizes are so you can order a keyed chuck. They should even be able to tell you what chuck they have that will fit it.
Jan 12, 2013 | Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
I have a drill bit stuck in my drill and I can not get it out of the chuck How can it be released from the chuck that I can change to an other drill bit.
By stuck do you mean that you can not release the chuck? if so then you can use 2 channel lock pliers to grip the chuck and the base to break it free. i have done the same on a keyed chuck and a keyless chuck .
Oct 03, 2010 | Garden
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Keyless chuck is locked in open position
First thing i would do is look inside the keyless chuck. Use a flashlight if necesary. If the 3 sliders in the chuck are the same ditance from the front then it is just stuck. If they are not then the chuck is jacked and needs to be replaced. If they line up the same then the chuck may have been on a bit of a bind, and then had some contamination in it. Usually rust will happen in here if it is humid where you live. The next thing to do is spray a bit of WD-40 or equivelant into the open chuck. Next thing to do is to put the drill in gear to go forward. Put a leather glove on your left hand to hold the keyless chuck. Set the clutch to maximum. Put the drill in the lowest gear it has and hold the chuck with the gloved hand. Pull the trigger as much as you can hold it as if you were sinching it down on a bit. If it don't break free then give it a sharp whack with a piece of wood from the side. (Don't beat the thing to death. One whack should do.) Try again. When you get it free'd up and you are storing your drill in the future it is always a good idea to leave the keyless chuck opened somewhere between all the way open, and all the way shut.
Presto.
Aug 20, 2009 | Drills
May 04, 2009 | Makita Drills
Drills Logo
100 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
