Question about Nokia 3230
Format harddrive of nokia 3230
My hand set is not working so i want format hard drive.please give me format password.
  • Nokia Master
  • 1,800 Answers
*#7970# then it will ask for ur security code default one is 12345
plz do rate this post as good as u can so we can help others
Posted on Oct 25, 2008
My phone 3230nokia, cannot read my memory card and the error message is {NO MEMORY CARD INSERTED}Please help me..Thank you
Posted on May 07, 2011
To on my Nokia 3230 mobile set its display hand and display nokia symble and set will be hang up. please help.
try to format using this code first turn off phone>remove sim and mmc>then press both of thish button >* >3 > calling button >on off switch when phone format it ask country select menu u can select ur country and go on......if ur fault solve don't 4get me thanx
Feb 17, 2011 | Nokia 3230 Cellular Phone
I have forgotten the security password in 3230 so how can i remove the password or format the set,when i am putting the format code it is asking security code.What can i do ?
The best thing is to format the phone.
To format nokia Nokia 3230 mobile please follow the below steps.
Please download the software called as 'Psiloc System Tools'.
You can download the system tool software from below website
http://gallery.mobile9.com/f/1047847/
Install it in your phone memory.DONOT install in your memory card because we will be removing the memory card.
Remove the memory card
Open the installed software.
Go to 'TOOLS'
You will find the option called as 'format phone',select it.
It will ask for confirmation, confirm it and it will format your phone.
It will restart while formatting and this process takes several minutes.
Once the mobile is started your mobile is formatted.
NOTE: Formatting will delete all your content from your phone memory.Take back up before formatting.
Thank you
Dec 15, 2010 | Nokia 3230 Cellular Phone
After formating nokia 3230 memory card is locked autometically
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 13, 2010 | Nokia 3230
Hi Sir=)
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 21, 2010 | Nokia 3230
Problem in nokia 3230
Power off the phone.
Press and hold Green, * and 3.
Keep them held while Phone is powering on and for a few seconds after that.
It will Format your phone compleatly and bring it back to the Factory Setting.(But the data which is on memory card will not delete)
It will clear all the Codes or Passwords.
I am sure this is going to work.
Apr 14, 2009 | Nokia 3230 Cellular Phone
Refresh nokia 5000
1st Step
Formet Your Memory Card
All data transfer CD or Pen Drive or Other Drive
Then Format Your Phone Memory,
2nd Step
Restore Setting, please Early do you Anti Virus Soft. Install & do you upgrade, than give you scan all files or folder,
thanks
Mar 09, 2009 | Nokia 3230
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
My Nokia 3230 Not Powering ON
you want to HARD FORMAT, switch off your mobile phone 1st, then press and hold 3 keys at a time star key, green dial key, and no. 3 key. then switch on your phone.
do not unhold all three key's until nokia's logo come's [hand shake] . it's done. you have to select your city.
Jul 18, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 camera not working and giving errong on system error & retrive data will be lost can u give me suggestion
try formatting it first..if it does not work bring it to a cellphone specialist because the camera hardware might be the problem
Jan 28, 2008 | Nokia 3230
Nokia 3230
Hi Back up your data and then enter this to try a soft format: *#7370# This will soft reset the phone if that dosen't work then try this *#7780# (restore factory settings). If this doesn't work you have one option left: hard format. Press simultaneously Green+3+*+power on. DO NOT RELEASE ANY BUTTON UNTIL "FORMATING" IS DISPALYED!
May 05, 2007 | Nokia 3230
Nokia 3230 Logo
211 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
