Question about Behringer Pmp3000 16 Channel Audio Mixer
Schematic for Behringer PMP3000
Need to identify components in the power supply. They do not have printed part numbers and therefore can not be identified.
  • 430 Answers
4 Suggested Answers
  • 5603 Answers
SOURCE: im looking for a curcuit diagram for the
If the supply failed I can tell you which parts to replace... and if it failed there may be a failure in the power amp that caused it. You can contact be directely at fredy2 @ aol.com... put Behringer in the subject.
The supply when it fails takes out eleven components including two expensive IGBT transistors. If the rearmost amp fried, add at least four more components and a lot of work carving out burned board and wiring around the blown circuit traces.
Posted on May 30, 2010
caroldon
  • 17130 Answers
SOURCE: Hello, Is (are) the schematic(s) for the Behringer
Please check the link below for help to the manuals
http://www.behringer.com/EN/Products/PMP3000.aspx
Please find the link to the support site to register your product or to seek the nearest support center. click on the link below;
http://www.behringer.com/EN/Support/
Posted on Mar 12, 2011
  • 5603 Answers
SOURCE: power surge has blown components
Behringer re-uses a lot of design... you might look at page 2 of this download:
http://elektrotanya.com/behringer_pmh100.pdf/download.html
Scroll down to "Get Manual" and click to download. On page 2 is the SPS400 power supply which is one of the smaller switching supplies they use. You may find the schematic is close, possibly they de-populate it as a smaller supply. When repaired, start the supply for testing with a 60 watt light bulb in series with the power input. Use an isolation transformer for troubleshooting for safety.
Posted on Apr 27, 2011
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
How do I get a schematic diagram for behringer europowr 2000
Try http://elektrotanya.com You can download 2 circuits per day for free, or pass an electronics test & create a login to get access to more.... Good Luck!
Dec 21, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
I need to know where can I purchase a fuse for Behringer PMP2000 10 Channel Mixer
If the fuse blew, you ARE going to need a lot more than a fuse as the cause is usually internal damage to the amp module and or power supply. Replacing the fuse without repairing the cause USUALLY causes more damage.
Oct 09, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Is burning my component, I need trasistor M50D060 s thank you
You have bigger problems than just the IGBT. I replace that part with part number:
APT28GA60BD15
About $6.50 from Digikey.com
You will probably find one or both of the gate speedup diodes blown PN DL4148 surface mounted an one or more of the driver transistors 2SSA1020-Y and 2SC2655-Y blown and usually the IR2153 switching regulator chip. If you haven't blown the 10 ohm ceramic pre-charge resistors you are lucky. Put a 150 watt lamp in series with the power cord to save fuses and parts till it is repaired. If you don't have schematic get back to us.
Aug 29, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Part for mp3000 position R1 37
Your description is inadequate for me to give you help. R1? and what is the 37? and is this on a PMP3000?
Here is schematic for a PMP3000 if that will help:
There are multiple files compressed... you can use the RAR decompression without paying.
At the website above, scroll down and click on "get manual" to download the service manual. Ignore the other download links.
Jun 23, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Power surge has blown components at input to the power supply unit SMPSU17. I need schematic to help identify the correct replacement components. John at Topaz Repair Limerick.
Apr 27, 2011 | Behringer Active 150Watt PAMonitor Speaker...
How do i plug in xp 4000 do i need balanced or un balanced to pmp 3000 tell methe whole story please
What is an XP4000 ??? Searches come up with coffee makers and un-interuptable power supplies.
No audio devices appear to have this model number.
Dec 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have Behringer pmp 2000 mixer but it burned my fuse. How can I buy it?
If the fuse blew do NOT replace it till the unit is serviced or you will burn up more components. These units will blow out from a minimum of three to 30 components when they blow.
There is weak insulation between layers of the power amp circuit board and the arcing destroys a minimum of three transistors and often many more components on the power supply board as well.
I have repaired several of these and it is a lot of work. The power amp module can be had for about $175 but it often takes out the power supply as well.
Jun 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Im looking for a curcuit diagram for the switchmode power supply in my Behringer PMP3000.
May 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
925 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
