Display shows !00% 8.5 x 11 std. Won't print
    Genius:
  • 2,120 Answers
Unplug the power cord for 10 seconds.
Posted on Oct 24, 2008
Hi i have a 97 dodge caravan 3.3 liter and the check engine show up then i go for the scan code it show up std catalyst what is that mean std anyway .code are p1776,p0740,p0401,p0140,p0700
Auto Zone or Advanced Auto or most auto part stores offer a free scan and print out of your codes and what they are. The possibility is #1 O2 sensor, #2 O2 sensor, Mass airflow sensor, Cam position sensor and preheat sensor. All of these sensors talk with each other and if one goes bad, they all give codes. Make sure that there are not breaks or holes in your exhaust system.
Apr 04, 2014 | Televison & Video
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
I have a density riverspas hot tub and it is stuck in sleep mode and there for won't heat up how do I take my density riverspas hot tub out of sleep mode
Difficult to answer without knowing the "Brand" of your Spa Support Pak System. Lets presume you have the most common basic pak available - Balboa.
Press "Temp" button and then immediately press "Light". You will then sequence between 3 modes:
  • Economy - may display as Ec
  • Standard - may display as Std or St
  • Sleep - may display as Sl
Should save last setting
Dec 03, 2012 | Pool & Spa
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Does anyone know how to reset the toner levels in an HL3040, i have put new colour toners in and each is still showing empty
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Nov 01, 2010 | Brother HL3040CN Laser Printer
How do i fix high saturation
Press the Func. button to diplay color modes in the little display.
When the display shows Color to the far left, you can switch color modes on the button below. STD is standard saturation, HIGH is high saturation, ORG. is less saturated that STD, and finally B/W
Jul 06, 2010 | Fuji FinePix S2 Pro Digital Camera
T-2642 restore CDs not working
After you instll from norton ghost, when you reboot pc, press f8 go to safe mode, once in safe mode go to device manager, change display Adapter to std display, monitor to std monitor, ide drive to std ide controller,
Feb 07, 2010 | E-Machines T2642 PC Desktop
Input a number and then show the fibonacci sequence of the input number in a C++ program.
I'm assuming one of two things, either
A) You need help for a programming class?
or
B) You're just curious?
Either way
#include <iostream>
#include <algorithm>
using std::swap;
using std::cout;
using std::endl;
// Function f returns n'th Fibonacci number
// It uses Algorithm 2C: non-recursive loop
unsigned int f(unsigned int x) {
unsigned int x1=1;
for(unsigned int i=1,x2=1;i<=x;i++) {
x1+=x2;
swap(x1,x2);
return x1;
// Function f_print prints out n'th Fibonacci number
void f_print(int n) {
cout << n << "th Fibonacci number is " << f(n) << endl;
// main is the entry point in C++
int main() {
f_print(46);
Feb 18, 2009 | Computers & Internet
Calculate the value of pi
#include <iostream>
int main(int argc, char *argv[])
double arctangentOfOne = 0.0;
for(int i=0; i < 1000; ++i, std::cout << 4 * arctangentOfOne << std::endl) arctangentOfOne += (i%2==0?1.0:-1.0)/(2*i + 1 );
system("PAUSE");
return 0;
Jan 15, 2009 | Microsoft Windows XP Professional With...
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
24 people viewed this question
jasbo
jasbo
