Question about Husqvarna Viking 1
Viking 6430 hand wheel is stuck
Where can i oil the machine and check the belt
4 Suggested Answers
  • 46 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
bbragg77 is mostly correct. It is not the camstack. Although they will crack, but that is all together another problem. It is the stitch length/reverse mech. You can manually work it back and forth to free it and I like to use break cleaner to get it free then re lubricate. A good service shop can put you back in business. And yes Viking does not support 6000 series machines any longer.
Posted on Jul 25, 2009
Sewtech1
  • 69 Answers
SOURCE: Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Posted on Jan 26, 2010
  • 371 Answers
SOURCE: viking sewing machine 940 needs spare parts
Certified Viking parts are only available from an authorized Husqvarna Viking dealer. However, there are some third party parts companies online. You should be able to find these using Google Search. However, I strongly recommend you have the machine serviced through an authorized Husqvarna Viking dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
Low gear
In that old a machine I suspect the grease and oil of the mechanism has gotten hard (waxy) and is causing the gear mechanism to stick. Most likely it simply needs to be taken apart, the old lubricant removed, and new grease and oil added.
Mar 23, 2014 | Husqvarna Viking 1
Viking 6430 bobbin winder post won't pop out
if the bobbin winder spindle won't move at all, it could be damaged, it would be a good idea to have the machine checked.
Aug 21, 2013 | Husqvarna Viking 1
What do u oil on 6030 viking
some sewing machine can be oiled some are self oiling, it would
be a good idea to contact viking sewing machine customer service
and ask them, here is a link for a manual to see if it has the
information you need
http://www.sewingpartsonline.com/instruction-manual-viking-6030-6270-6430.aspx
Nov 28, 2012 | Sewing Machines
How to clean a Viking 6430 sewing machine
You can find extensive information here: http://stitchesandseams.blogspot.com/2010/04/review-viking-6010-sewing-machine.html.
You really should get a manual. It will give you all the details about cleaning your machine. You start by opening anything you can (be careful with the screws and plates - I keep a magnet for holding these while I clean) Take a pipe cleaner and/or a small sewing machine brush and get out any lint. This is where you first need your manual. It will tell you how to clean the bobbing case. After all lint is removed, you will need to oil it in certain spots...again, you need the manual for this. Always use sewing machine oil in your machine. It is different than other oils. You can download your manual here: http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6430. I think they charge $7 for it.
Jul 08, 2012 | Husqvarna Sewing Machines
Jan 25, 2010 | Husqvarna Sewing Machines
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Jul 14, 2009 | Husqvarna Viking 1
Needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Mar 14, 2009 | Janome Sewing Machines
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
