Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Sears 30,000 but heater will not stay running.Rnus for about 2 mins then stops.
Runs for mabybe 2.mins then kicks off.
  • Dale James
    Dale James Feb 13, 2012
    Heater runs for a couple min. then quites running when it does run it no longer produces heat.
  • 430 Answers
The conpresor stay on about 10 min. then shut off 20 min then kick back on. fan stay runing
The compressor needs to stop every so often as to not build up too much pressure in the refrigerant line. The blower fan can continue to run for a while afterwards because the evaporator is still cool; overall, it's more efficient this way.
Aug 08, 2011 | Friedrich Heating & Cooling
MY AC UNIT WILL RUN COLD AIR FOR 2 MIN THEN IT WILL KICK OUT WITH ONLY THE FAN RUNNING. wAIT 3 MIN IT WILL KICK BACK ON FOR 2 MIN THEN STOPS AGAIN. WHAT DO I DO TO FIX THIS PROBLEM?
Clean the outdoor coil, slide the unit out of the case, take a garden hose and nozzle to it use a solid stream of water, and watch the fins that you do not damage them with the water. Clean the indoor coils as well, and check to see if the motor is oilable. Keep the water out of the other components.
Jul 08, 2011 | Fedders X Chassis A6X05F2B Air Conditioner
Heater will not stay running after i take my hand off ingnitor
The thermocouple has gone bad. They're are easily replaced and can found at the place you purchased the heater. Or online from Ready Heater.
Jan 26, 2011 | Reddy Heater-30,000 BTU Propane Forced-Air...
Red led blinking three times, furnace kicks on, runs about 10 seconds gas flow stops and it recycles, heats up runs for ten seconds
check flame sencor is clean or loose connection , or it could be the pressure switch try jumping it out and see if it stays on ,
Nov 10, 2010 | Goodman GMS90703BXA Heater
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My heater won't stay running
if you get heat when it runs and then it shuts downs you need to clean your flame rod or replace the thermocouple if its a pilot lit furnace
Feb 06, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I have a goodman will lit run for 2 min and then go off
sounds like you have a bad control board or limit control
Apr 23, 2009 | Goodman GMS90703BXA Heater
bigrench1843@aol.com. I just fix this same problem 15 min. ago after 2 days of headbanging
915 EST. lets talk
Jan 28, 2009 | Reddy R155D Utility Heater
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
265 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
