Question about Denon Dnx300 3-Channel DJ Mixer System
Need a crossfader for the denon x300
I need a crossfader for the denon x300 and 1 kill switch on the right channel ????
  • 430 Answers
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
Can i connect bose 901 to denon avr891? with 901 eq that required "tape monitor '
Two problems:
1) You have no specific Front Right and Left Pre-Outs. Using the available DVR Out, for example, would feed mixed-down stereo full voume programming instead of volume-controllable Front Channel-only output.
2) If you had them you would still need a separate amp for the 901's as its Active EQ is unsuitable for 'normal' non-901 speakers and engagement of any analog processor in an analog tape loop (like DVR Out/In) would effectively kill any digital source. It WOULD only work for analog sources.
Jan 05, 2011 | Denon AVR991 Receiver
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My Behringer DX626 Mixer got beer spilt on it, and i got it back from repairs today, but it seems as channel 2 / the crossfader still doesnt work. e.g i have crossfader in the middle, and both channel 2...
sounds like the beer short circuited the equipment, the people who tryed to fix it didnt do a good job seems like, try taking it apart an use a cue tip an find any beer fragments that could remain in the unit, that mite be the problem
Oct 24, 2008 | Audio Players & Recorders
Gemini tt02 no sound!
phono \line switch the right way maybe.have you got signal on the mixer from dodgy deck
Aug 20, 2008 | Philips gemini TT-02 Turntable
Whats a crossfader
The cross fader switches the source from one input to the other input. D.J.'s use them to fade from one song into the next one they are going to play when using 2 different turntables or 2 different cd players..
You did say in your question that you needed a crossfader.
Hope this helps Brittany.
What's the 721 stand for?
Dave
Jul 01, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
Tapco MIX60 6-Channel Mixer
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
http://www.bswusa.com/proditem.asp?item=MIX60
Jun 30, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
Denon Dnx300 3-Channel DJ Mixer System Logo
263 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
