Question about Makita RST210 2 Stroke Petrol Line Trimmer 21cc
My makita petrol powered stone cutter wont start
Wont start
  • john dawson Feb 18, 2012
    ive checked spark plug gap and spark ok,removed carb and found this to be starved of fuel ,yes theres petrol in
  • 430 Answers
Manual required for Makita DPC6400 stone cutter
Go to the Makita home page at:
http://www.makitatools.com/en-us/Modules/Home/Default.aspx. Use the search box at the top right to look up your model. It will show it is discontinued but if you select it you will be able to view or download the parts breakdown and owner's manual.
Oct 27, 2012 | Makita Saws
I need a piston and barrel for a makita dpc8112 stone saw
The cylinder and piston sell in a kit under part number 326-130-051. You can find it on websites like http://www.ereplacementparts.com/ but it costs $317 plus shipping. You may do better to find a local Makita service center that can order the part for you. Go to the Makita website at www.makitatools.com/en-us/Modules/Home/Default.aspx and look under the Services tab for a service center search box.
Apr 15, 2012 | Makita DPC8112 16" 81CC Gas Powered Power...
Makita petrol stone cutter
Start by removing the wire from the cut out switch to rule out a problem with the switch, if still no spark with a new plug it will be a replacement ignition unit.
Feb 12, 2012 | Saws
My makita 6410 started first pull ,cut about three bricks now wont start, it pulls fine and sounds like it wants to start but wont, i think i may have put too much oil in, will this cause this problem,...
yes to much oil with the petrol will cause problems i`m afraid the carb is now blocked with oil and will need cleaning out problem is that the carb is micro chip controlled and it will need to be cleaned out at a repair/service center
hope this helps
John
Sep 14, 2011 | Makita DPC6410 64cc 12" Power Cutter
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
No operators manual for makita dpc 6410 petrol disc cutter
Come on, it tooks me 20 seconds to find it...Web search is all about keywords. makita dpc 6410 manual leads to the answer. Adding pdf would have been even better...
Aug 01, 2009 | Makita DPC6410 64cc 12" Power Cutter
Makita RST210 2 Stroke Petrol Line Trimmer 21cc Logo
183 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
