Honeywell pro 3000 thermostat wiring giagram for rheem heat pump
Therinnaiguy
  • 1420 Answers
SOURCE: Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Posted on Jan 16, 2008
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Posted on Jan 05, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 588 Answers
SOURCE: I Have a honeywell RTH2410 Thermostat I wired it
What was the old thermostat labels and the wire colors that went to them?
The typical heatpump wiring Terminals are:
R = Red = Hot side of Transformer
C-B-X = Common side of transformer Depending on brand of heatpump
Y = Yellow = Cooling Contactor
G = Green = Furnace Blower
O = Orange Reversing Valve Energize to Cool
B = Blue Reversing Energise to Heat Depending on brand of heatpump.
W2 = White = Auxiliary Heat
You need to be sure where each wire comes from when you connect them to the new thermostat.
The best way to do that is to go to the furnace and see where they are connected. R-Y-G are probably correct, you need to see where the Blue wire comes from and determine what the X terminal was on the old thermostat.
Posted on Dec 29, 2009
Can I replace a faulty Robertshaw 9600 thermostat with a Honeywell TH3110D1008 Pro 3000 (I don't need a programmable thermostat)
yes, provided the same number of wires are used in both. Try programming thermostat to the same temp day and night All timme periods 7 days a week. this will turn it into a manual thermostat. Refer to Robertshaw manual for directions.
May 08, 2018 | Honeywell Heating & Cooling
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
I have a new Rheem heat pump. The cooling works fine but won't blow hot air in HEAT setting. I have reset the breakers for heat pump and air handler, changed filters and pulled batteries and reset the...
if this is indeed a heat pump you rthermostat should also have a emergency heat setting does it work on that setting... a heat pump on heat wuns the outside unit and has a recersing valve that changes the refigerant flow ..is the outside runnignduring heat mode... if you turn the thermostat in emergency heat the outside should shut down and indoor heat should come on...of this is not happening you have a wiring issue if both are not working... braeburn thermostats usually have behind the cover dip switches... i am not exactly sure what model this is but if indeed a heat pump the thermostat should have a r,w2,y,e,g,c,o,and b terminal... rheem wiring should be as follows
red to r white to w2 , g=green , yellow to y terminal there should be a wire hooked to the b terminal usually brown sometimes orange on the b terminal that is your reversing valve terminal.
you are going to have to make sure the thermostat is configured to energize the b termianl and will have to go into the installer setup to do this...hopefully you still have the paper work on thermostat... most heat pumps use the o terminal for reversing valve but rheem uses the b terminal
hope this helps out some repost with anymore probs...also make sure the switches are set to electric or gas whatever you have heat pump or not etc. inside thermostat
Jan 05, 2011 | Heating & Cooling
Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Mar 04, 2010 | Heating & Cooling
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Wiring diagram to connect programmable Thermo to Heat Pump
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell PRO 3000 thermostat is not activating the cooling system when prompted.
R==power w=heat y=cool g=fan remove the front cover to reveal the 4-wires and take a jumper wire from r-----to ---g ,to see if the fan operates. Then take the jumper wire from r----to--y, to see if the cooling system works outside, because when calling for cool, the thermostat is internaly connected to g--for fan.. Then if it kicks in, then you have a bad thermostat!
Sep 04, 2008 | Honeywell Heating & Cooling
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
