Question about Polaroid LCD-2050 20 in. Television
Ariel socket in tv has broken
Polariod tlu 01911cu flat screen TV. The airel socket has broken, can I replace it(myself)?
My house is fitted with old Cable and Wireless TV ariel fittings, which dont fit the TV ariel connectors I have just bought for a small flat screen in the bedroom. I can find any adaptors, seems the only option is cut the end off and replace, any ideas
Posted on Nov 30, 2008
  • Polaroid Master
  • 19,396 Answers
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Posted on Oct 24, 2008
Broken ariel input on back of tv
the cover has to come off and the old or a new connector needs to be soldered in.
Sep 22, 2015 | Samsung UE42F5000AK 42" LED TV 1920x1080,...
My tv is a sony fwd 40lx1, it will be connected to a sky+ box, but theresno scart on the tv
Use the RF 1 socket on the sky box into the ariel socket on the tv.
Pick a channel number on the tv and tune it to frequency 68.
Oct 11, 2014 | Televison & Video
Philips powervision tv my tv tuner pin is broken
You're discussing about the input socket [Ariel socket] to your TV is broken; I assume, and posts this solution. In most cases, this is a irreparable fault; because, this socket is directly connected to the tuner, and is a part of tuner body [case]. If it is broken, the the tuner should be replaced with an identical one. You should check out the number of the tuner used with your TV; can be noted on it by a sticker. Just buy that number tuner, and replace it. The tuner can be bought from most of the electronic spare part selling shops.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | Televison & Video
Toshiba tv no place to insert my ariel
Your problem is the tuner socket has broken off. You can either install anew tuner unit or replaced the tuner socket which is a bit more fiddle.
Jan 09, 2014 | Toshiba 14AF42 14" TV
The antenna/cable connector looks broken. can this be replaced?
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
Polariod flat screen tv when powered up power
your right there will be a bad caop in the power supply the can will have a domed or puffed top the value is printed on the side replace it and it will all set to go
Dec 23, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid TV TLU-01911CU - no TV signals via analogue input?
Tries the web.because not popular tv brand it hard tv find parts for.It not cost effective for the
manufacture to produce very much extra parts.
tries these websites.Tv Repair and might have ur parts.
Sep 03, 2009 | Televison & Video
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
Broken coax input to back of tv
Nov 12, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Polaroid LCD-2050 20 in. Television Logo
179 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
