Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Where do i buy a cooling fan for a mitsubishi wd 52327 tv
    Champion:
  • 453 Answers
Radioshack
Posted on Feb 12, 2012
  • 192 Answers
SOURCE: electrical chasis cooling fan for Mitsubishi wd 52525
There are several Parts Houses that carry this part. The one I think that is the easiest to deal with is Andrews.
The URL is:
https://dealer.andrewselectronics.com
Can't find it there, reply to this post and I will respond.
Posted on Dec 15, 2007
SOURCE: mitsubishi wd 52525 chasis cooling fan
That should work. but make sure that the voltage form the wires are DC and not AC. In addition, depending on the original fan the RPM's maybe different. If you do replace with a computer fan just make sure the flow feels reasonably good.
Posted on Dec 24, 2007
SOURCE: Tv brightness
the light engine is that part that displays the picture on the screen. its like a filmprojector. if you need the complete LE, you run in about 1200-1600 dollars.Mitsubishi DLP's are known for collecting great amounts of dust, so try to clean the filters first and remove all the dust you can find.be careful,do not use a vaccuum as they can damage the electronics and the fans.....
Posted on Jan 11, 2008
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
asnowman
  • 788 Answers
SOURCE: status lamp lights-up on front no picture
The lamp is not that exspensive you should be able to get one for around $150 and you can replace it yourself.
The lamp can be bought as a lamp or you can order the entire cartridge, I would suggest the cartridge, unless you are handy at taking things apart as the cartridge can be tricky to take apart without breaking it. The only difference will be the cost. It is your choice. The Mitsubishi part number is 915P020010
You can google this and find many places to purchase the lamp or cartridge on line.
Replacing the Lamp Cartridge Tool needed: Phillips screwdriver
1. Turn the television off and unplug the AC cord.
2. Remove the front speaker grill by gently pulling on each side. The grill will snap out.
3. Using a Phillips screwdriver, remove the three screws (one on the left and two on the right side) that hold the recessed plastic cover in place.
4. Remove the plastic cover and set aside with the screws.
5. After removing the cover, you will be able to see the lamp cartridge. With the screwdriver, loosen the threes crews of the cartridge. The three screws will not completely remove.
6. Gently grasp the metal handle and pull straight out (towardsyou).
7. Insert the new lamp cartridge securely into the TV. Do not touch the glass surface of the cartridge.
8. With the screwdriver, tighten the screws on the lamp cartridge.
9. Replace the plastic cover and screws.
10. Snap the speaker grill back into place by pushing it into place on each side with the palm of your hand.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 01, 2009
Testimonial: "thank you very much you told me me exactly what i needed to know your the man thanks again louis"
Tv turns on works for awhile then shuts down
it seems cooling problem check if fan is working or not
and check the english user guide
http://www.manuals365.com/swf/mitsubishi/wd-62327.html?page=50
Mar 17, 2015 | Mitsubishi Wd-52327 52" 1080i Hd Dlp...
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Bulb went out for the 2nd time in less than a year on Mitsubishi WD52327. Also making a loud grinding noise. What is my problem?
the grinding noise is from the cooling fan that cools the bulb. It needs to cleaned or replaced. You will need to take the back cover off the set to get at it. If the cooling fan is not doing its job that would cause the short bulb life and the noise
Jan 03, 2011 | Mitsubishi WD-52327 52" Rear Projection...
I have a Mitsubishi 57" projection tv, Model# WD-Y57. There appears to be some type of liquid betweent the 2 screens. Is there a way to clean this, or do I need to buy a new screen?
Remove the 2 screens and clean then wirth only micro fiber cloth and mild cleaning solution dry and reassemble. be sure to put back screens in same ostions.
Feb 18, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
