Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
Flushing problems I have 2 Kohler toilets in my apartment. They were installed approximately 2 years ago. One, the first one installed has always worked properly. But, the second one, exactly the same model (I don't know the model but it is a one piece long bowl toilet) has never flushed properly. The flushing mechanism has always been loose and difficult to tighten in a way that stays tight. However that is not the real problem. Generally I have to hold the handle down to get it to flush. And when it does flush, often it has to be flushed a secodnd time as the flow of water is so slow the bowl doesn't alwyas clear all the way through.
    Top Expert:
  • Kohler Master
  • 12,962 Answers
Tank needs more water and the flapper has to stay open longer by adjusting chain so the flapper goes up higher when you flush the unit. Practice and you will get it right.
Posted on Apr 09, 2017
  • 90 Answers
SOURCE: Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
Posted on Jan 23, 2009
  • 146 Answers
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Posted on Jun 24, 2009
  • 76 Answers
SOURCE: Kohler one-piece has no flushing power
try to increase the amount of water for each flush .
Posted on Jul 17, 2009
  • 32 Answers
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Posted on Aug 16, 2009
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
Water not stop running into toilet when flush on Kohler pull up top flush toilet
Replace the flapper even t looks good the loose the ability to seal
Sep 06, 2017 | Cars & Trucks
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Water in bowl. water level almost below where bowl saris to widen! , Kohler cimmarron - Toilet tank is full, all water flushes out of tank when flushed it's been this way since we installed it
If I understand correctly, your water level inside the bowl is 3 or 4 inches from the top of toilet seat?
Sounds peculiar to have that water level since you would get splashing etc.
That is not sanitary, and would be a code violation.
Look at side profile of tank.
Look at porcelain behind bowl and you can see outline of "s trap."
This is the internal trap that each toilet has built in.
Purpose of trap is to a) set water level inside bowl and b) just like a sink trap, seal pipe from sewer air from entering home.
Photo shows trap on sample toilet, with line showing approximate level of water inside bowl.
Since photo is at an angle, the line appears to go downward instead of level. Again the line is approximation, and photo intended to show where you can look on your toilet.
Your tank should have similar s-trap feature. From the feature on your tank, you can see what level water is intended to be inside bowl.
Some more expensive tanks, outline of s-trap is not apparent.
If the water level is so high that you experience unsanitary conditions, this is a code violation, and toilet should be replaced.
Quick web search turned up Kohler contact page:
KOHLER Customer Care at
Phone: 1-800-4KOHLER (1-800-456-4537)
Hours: 8:00 AM - 5:00 PM (Central Time) Monday to Friday
You can refer Kohler to this link on Fixya so they can clearly understand issue.
Jan 09, 2011 | Kohler - Toilet - Two-piece - Highline -...
I installed this toilet one year ago it has wooked fine untill today. now it flush.I pulled it up from the floor checked out the drain and toilet ,reinstalled, still will not flush properly. Water does not...
You may have a slight restriction stuck in the goosneck of the toilet or in the pipe elbow.........If you have little ones they seem to test our knowledge sometimes.Hope this helps.
Sep 13, 2010 | Kohler Cimarron Comfort Height elongated...
Toilet takes vey long to fill the tank.
More then likely the power valve in your flush master ball valve is out.. Replace flush valve and should fix problem. Home depot sell fluid master for like 7.50
Mar 02, 2010 | Kohler - Toilet - Two-piece - Highline -...
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Dec 26, 2008 | Home
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
267 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
