Brivis wombat flashes 7 times lockout - Heating & Cooling
  • 148 Answers
SOURCE: brivis central heating fan will not switch off runs continuous
fan limit switch
Posted on May 12, 2009
SOURCE: Air blowing out - Pilot on but no heat.
Possibly overheating or previously overheated, these units are also prone to control box issues usually a buzzing noise at the unit it present if this is the case.
Posted on Apr 28, 2010
  • 2973 Answers
SOURCE: heater will work but cooling
If the compressor is running and there is still no cooling then the gas (feron) may have leaked out. It has to be refilled to make the unit work again.
Posted on Nov 24, 2010
  • 81 Answers
SOURCE: Brivis gas heater - Wombat
Take fan apart - easy. Clean with WD40 and then oil with 3and1
Works on all fans.
Posted on Jul 19, 2011
  • 3253 Answers
SOURCE: pilot light is large and
blocked pilot , lack of air so it burns yellow needs blowing out with air line or can of air , or undo and clean pilot .
Posted on Jul 26, 2011
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
Brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Jun 12, 2012 | Heating & Cooling
Pilot light is large and yellow on the brivis 92 wombat
Jul 25, 2011 | Heating & Cooling
Brivis gas heater - Wombat 20 - fan doesnt seem to be operating at full speed
Works on all fans.
Jul 15, 2011 | Heating & Cooling
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
Apr 28, 2010 | Heating & Cooling
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
