Bought a Shift wireless indoor/outdoor speaker from Office Depot & enclosed AC adaptor Model RGD48120120 plug is too big to fit in the plug hold on the speaker unit
The power cord is for the speaker and not for the transmitter. I use AAA batteries for my transmitter and it worked just fine. Hope that helps.
Posted on Feb 02, 2009
Ii thought that too, but it doesn't go into the wireless part, it goes into the back of the speaker. turn it upside down and you will see it.
Posted on Jan 15, 2009
  • 86 Answers
If it packaged with the speaker, then its office depots fault. i would replace it with another before the warrenty is out of date.
Posted on Oct 24, 2008
Is there a way to connect my Dell MMS 5650 speakers to a Macbook Pro laptop or a wireless router? Where can I find cables for converting? Thanks!
The speakers should directly connect to the "line-out" socket on your Macbook computer, without any need for adapters.
I have _never_ seen a wireless router that had _any_ "audio" capability -- what you're asking for seems to be unreasonable.
Any "Dollar Store" or the "big-box" stores (such as Best Buy, Office Depot, Staples, Future Shop, Wal-Mart) should have adapter-cables.
Aug 19, 2010 | Dell 5650 Computer Speakers
Hi. I have a failed indoor controler on a hitachi ducted aircon. mod ras-5hz. inverter. can I replace it with other type. Unit 15 yrs old and parts not available. What is the control voltage between indoor...
Hi, the control voltage to both indoor and outdoor will always be 24 volts AC. If this is a heat-pump unit, the high voltage to the indoor and outdoor will be the same, 208/ 230/ 240/ 277. If it is a split unit with a gas fired unit, the outdoor will be 208 or higher and the indoor will be 120volts AC. I'm sorry, you have the inducer motor, so it is gas! My mistake. Yes, always the gas furnace will be 120 volts AC and the remote condenser will always be 208 and higher. As far as replacing the inducer motor with a different kind, it will have to be the same voltage, 120, and amps, R.P.M's, 60hz, and made to pressurize and be able to vent Hot gases also. It must fit and operate like the old one. They should make a replacement universal motor to fit? Check with some of the wholesale houses on this and they can locate a motor to fit. Keep me updated on this please Don.
Shastalaker7
Dec 18, 2009 | Hitachi Heating & Cooling
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Dec 12, 2009 | Acu-Rite Audio Players & Recorders
I need a replacement AC adapter for a 900 MHz indoor/outdoor mono speaker by Accurian. It is model number AWS-1475. I need a 12V DC, 850mA, Plug type ''M''. Any idea where I can get it and how much it...
Radio Shack Sells Accurian they may need to special order it, or they may have one with a universal adaptor. Be sure to check polartity and current rating.
Nov 12, 2009 | Audio Players & Recorders
I have a 900 MHz Wireless Indoor/Outdoor Mono(Accurian)
yep the power to it is in question and since it is a 9 volt adaptor as mentioned that will need to be checked 9vdc adaptors are over the counter items in most radio shops
Jul 29, 2009 | Audio Players & Recorders
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
955 people viewed this question
 Grubhead
Grubhead
