Question about Hitachi 43UWX10B 43" Rear Projection Television
Blue screen My 43fdx01b hitachi rear projection tv was hit by lightning and now it will power up with a blue screen. The menu will display but no other picture. After warming up it sounds like a helicopter flying and the screen is blinking. Has anyone had this problem?
    President:
  • 3,130 Answers
Your tuner or PLL circuit is blown out. if you have homeowners call the agent. Good Luck
Posted on Aug 10, 2006
After a lightening storm, my power surge strip got hit and damaged everything that was attached to it (i.e. the internet modem, blu-ray player, and Samsung TV). Our TV only has a blue screen. Help
Yep, power spikes kill. Power spikes kill all. Power spikes kill all forever. Replace all and get a new surge protector that costs at least $99. If you never need it it is called insurance. I am in FL the capitol of lightning. High priced surge protectors are cheeeeep when lightning is there.
Sep 24, 2018 | Samsung Televison & Video
I have a 50inch DLP Hitachi that is 3 and a half years old. I replaced the bulb about 5 months ago now the blacks are blueish and it has a greenish blotch on the screen. It also leaves an image on the...
Contrary to popular belief, any display product can have "Image Retention" and even "Burn-In". This is true for Plasma, LCD, LCOS, DLP, and CRT. I do not see a model number provided, but I would bet that you have an LCD rear projection TV rather than a DLP projection TV. If this is the case, the Blueish and Greenish blotches you are seeing on the screen are the result of UV light damage. UV light will move heavily damage the Blue panel, due it's short wave length. So, bad Blue or Green (absence or Blue) is typically the the first visual indicator of a problem. Replacing the Light Engine will resolve the problem.
Mar 15, 2010 | Hitachi 43FDX01B TV
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Hitachi projection model #43fdx01b.distorted color, blue off set. Half moon line at the top, taking top part of picture.
Ur convergence is dead.U need buy a convergence kit,U know how to solder right?Buy it at these websites.Tv Repair World.com or Ebay.com.
Sep 30, 2009 | Hitachi 43FDX01B TV
Images on screen have shadows
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
No power
When I turn on the tv, there's the green light, that shows it's on, but it's blinking green and the screen is black
Jul 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
43fdx01b arc at top of screen
Usually this means convergence ic's have to be replaced and possibly a few resistors on small convergence board. Sometimes it requires digital alignment after new parts are soldered in. This repair can cost 175.00-375.00.
Apr 20, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Digital Array?
Replace IK04 and IK05, both STK392-110, but use instead STK392-150's for greater reliability. And don't get some Chineese knock-offs - use original Sanyo replacements. If you don't know where to get those try ACME Enterprises in Florida,
http://www.acme-sales.net/index.shtml
Also measure the low ohm feed resistors in that circuit. However usually just replacing the convergence amps will restore normal video...
Bill
Nov 17, 2007 | Hitachi 43FDX01B TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
