Question about Exercise & Fitness
I have a starcraft tx350 and when i set the speed it speeds up
When i set the speed on the treadmill it speeds up
    Top Expert:
  • 12,223 Answers
Dear Sir:
Please RUN your Software calibration, most them the instruction coming from the Hood of motor, and follow the steps, or your user manual, if you do not have, go to the next web: fitness.manualsonline. com and download for free.
The software is for easy Diagnose and Troubleshooting.
Adjust the sensor speed see the diagram, tight the wires from the sensor speed, and the software will be detect it is faulty. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
i have a starcraft tx350 and when i set the speed  - 2_16_2012_11_47_41_pm.gif
Posted on Feb 16, 2012
2 Suggested Answers
SOURCE: Have a sportcraft tx350 treadmill and it won't
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Posted on Mar 14, 2011
Tip
OS or O5 Error on Landice L-Series Treadmills
Probable Cause
An OS or O5 error on the Landice L-Series treadmills, such as the L7, L8 and L9, indicates an over speed condition and this occurs when the actual speed of the running belt is faster than the set speed. The possible causes for an overspeed, OS or O5, error are: A) User weight is over 200lbs, treadmill elevation is set between 10% and 15% grade and speed is set between .5 mph and 3 mph
B) User is pushing against treadmill belt causing it to go faster than the set speed
C) Defective lower board or misaligned speed sensor
D) Maladjusted speed potentiometer
Corrective Action
A) Gravitational force will enable the user's weight to move the treadbelt faster than the set speed. The speed sensor will pick up this increase in flywheel speed and sends this information up to the display electronics. The microprocessor will then compare the actual speed to the displayed speed, determine a runaway speed condition and shut the treadmill down. An overspeed will display in the window. This is a safety feature built into all treadmills that utilize closed loop speed circuitry. The way to address an over speed condition due to gravity is have the user decrease elevation below 10% or increase the speed.
B) Similar to the gravitational force, a user can be holding onto the handrails and pushing the running belt in such a manner where they are using the treadmill like a manual machine rather than a motorized one. User needs to set speed compatible for their actual walking or jogging speed so they are not pushing the belt.
C) It's possible a blown motor control board is the problem. This occurs more frequently with PWM drives than SCR drives. However, this problem is becoming rare due to the PWM circuitry which senses this condition and shuts itself down before the drive motor receives any DC voltage at all. This means you'll get an LS or L5 error if your PWM is blown, not an OS or O5 error. This is a safety feature on all Landice home treadmills with PWM motor control boards. The SCR motor control boards also have internal protection to prevent an over speed condition from occuring due to an internal component failure. In the rarest of cases, on home treadmills, a faulty relay board can cause an OS or O5. To verify this, using a digital voltmeter, with treadmill turned on, measure the DC voltage between the V+ and P1 on the PWM board. The reading should be between 6-7 VDC. Also measure the DC voltage between P1 and P2 on the PWM board. The reading should be between 0.5 VDC and 6-7 VDC. If either of these voltages measure zero, replace the relay board.
D) Get into Open Loop Speed mode and check the speed. Adjust pots as necessary to bring up correct speed for max and min.
http://www.sportsmith.net/support.aspx?did=BAB0DA9A-857E-41B3-A1DD-3DC0663BB9A4
on Apr 10, 2015 | Landice Exercise & Fitness
Tip
How to reset/recalibrate your treadmill after replacing drive or incline motor,...
Make sure you recalibrate your treadmill after installing ANY controller, motor or console. You can NOT over calibrate your treadmill. You want to make sure you adjust your pedometer for the correct operating speed and incline adjustment. First plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. The adjustment is made with a phillips screwdriver, and the adjustment point is on the motor controller. It is a little square metal box with a yellow plastic adjustment screw inside. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode. Double check that the treadmill is operating at the correct speed and incline motor works correctly, by running maximum settings. Once you are done, be sure your treadmill is properly protected from surges from power spikes that can destroy the work you just performed.
Hope this helped.
on Dec 08, 2011 | Nordic Track Exercise & Fitness
Treadmill speed is going fast when I have it at 2.5
Your variable resistor (speed adjustment switch) is going out
Mar 23, 2016 | Sole Fitness F63 Treadmill
Need to order a control board
I am not sure they carry these boards but most certainly worth a call is Allied Electronics. If they don't have one I know they will steer you the right direction.
May 14, 2014 | Sportcraft Tx350 Treadmill Motor Speed...
I have a TX350 sportcraft treadmill, works great, but shocks our hands everytime we use it and we lost the user manual when we moved a few years ago. ?
I am not a fitness expert but I did want to pass along a few resources in case they may be useful. Here is a parts list for the TX350, and here you can search for treadmill repair companies in case you need to have someone in your area take a look at it. Hopefully you can find a solution without needing to spend money on repairs, though.
Mar 14, 2011 | Sport & Outdoor - Others
Seems to be stuck in a programcan't change speeds won't incline.have reset numerous times with no luck.
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | RTO Image 15.0R Treadmill Walking Belt
Will not move belt
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
Feb 25, 2010 | Exercise & Fitness
Exercise & Fitness Logo
44 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
