Question about Exercise & Fitness
Bally Mini Stepper Broken Pulley
I have a Balley Mini Stepper and the Pulley has broke. I can't seem to find anywhere that may carry that part.
Hi mine is not even a yr old and the pully broke, where can i find a pully.
Posted on Mar 18, 2013
95 LeSabre 3.8 serpentine belt removed you can turn crankshaft pulley forward and back about an inch and a half makes loud noise at times car still runs and drives possible broken crankshaft?
you should be able to turn it by hand or with a socket and ratchet broken crank means broken car if you broke crank which is rare you would not have a running engine sounds more like stretched timing chain if it feels sloppy
Jul 29, 2015 | Cars & Trucks
Tip
Replacing a Spring Pulley on Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Spring Pulley Replacement
  1. Remove the bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Remove the snap ring from th pulley shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  4. Slide pulley and washer off the shaft.
  5. Before reinstalling the pulley, clean the pulley shaft thoroughly with a clean, dry cloth. Apply a thin coat of multipurpose grease to the pulley shaft.
  6. Slide the pulley and washer onto the shaft. Install the snap ring.
  7. Route the spring under the spring pulley.
  8. Hook the end of the spring over the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
  9. Reinstall the cover.
How To Replace Spring Pulley on Stairmaster 4000PT
on Mar 10, 2015 | Stairmaster 4000PT Stepper
Gas gauge not working
The needle is attached to a stepper motor that receives information from the car's computer. If the motor starts to go bad, it will only move some of the time when the computer tells it to move, which can lead to it pointing in all sorts of weird directions.
In order to replace the stepper motor, you need to pull off the dashboard, remove the whole instrument cluster (which houses the speedometer, tachometer, oil gauge, etc), crack that open, desolder the motor from the circuit board, and solder a new one in it's place.
It's not that hard to do, really, but you if you screw things up you'll have to buy a new instrument cluster (or live without a gas guage, which you're basically doing anyway).
You should be able to buy a stepper motor for under $5. Just be sure it's the right kind for your car, since stepper motors come in all shapes & sizes.
Mar 04, 2015 | 2004 Buick Rendezvous
I need help with a 1999 plymouth, Voyager staling while driving down the road
While the engine is cold and OFF set park brake and get underneath and beat on the Cat Conv. if it rattles bad, you need a new one, because the baffles have broken out.
Hope this helps.
Jul 08, 2013 | Dorman 1999 Plymouth Voyager A/C...
Kia sedona, broke the bolt to the serpentine tensioner pulley, now what
Asuming you broke it off in a blind hole, if you have a wire feed center a nut over the remaning stud & weld if on let cool put penetrating oil on it & work it gently back & forth even if its below the surface slightly on aluminum or cast the weld will not bond to the surface just the bolt you may need to do this process several times then go to dealler for new bolt. Note this works extremly well on broken ex. manifold bolts, we havent drilled in years hope this helps Danny
Jul 27, 2012 | 2003 Kia Sedona
How do you remove a broken bolt on the timimg belt tensioner pulley for a 2001 300m crysler
!st remove the tensioner if it is still bolted in place by second bolt. Easy outs are high tensile you will not drill through it. You may have to carefully try to chisel it out. If you can get it out try a left handed drill bit if you have room to drill. If it won't come you will probably have to re drill & tap a new thread & use oversize bolt
Jun 22, 2012 | 2001 Chrysler 300M
My dryer's barrel will not turn. I have replaced the pulley and belt but that did not fix the problem. The pulley's tension is not tight enough to turn the barrel. I have the correct barrel and...
Hello Mwagner, sounds like the Idler bearing pulley assembly has come loose from the belt. It's job is to keep tension on the belt so the motor is able to turn the dryer drum. By watching some videos online it seems that alot of teardown is required to get to the part you need to inspect and or replace. Here is a link for you to look at that might help you. Samsung Dryer Idler Pulley Roller Replacement DC97 07509B
May 04, 2017 | Samsung DV316LES Electric Dryer
The pulley on the crank shaft that drives the alternator and A/C belt broke and I need to know how to remove and replace broken pulley.
You may need a pulley puller. Though this seems like a smart assed comment, it is the truth. They are ususally available to rent from your local parts store.
Jul 16, 2009 | 1992 Honda Accord
Exercise & Fitness Logo
179 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
