Question about Bose MediaMate Computer Speakers
Can the speaker wire attached to the accessory speaker be replaced?
Speakers have been stored in basement. Speaker and input wires have been chewed on by rodents, exposing wires. AC power adapter is fine, speakers appear unaffected but wires are trashed.
5 Suggested Answers
  • 135 Answers
SOURCE: loud whining noise
yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Posted on Jul 06, 2008
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Posted on May 07, 2009
oldskool55
  • 51 Answers
SOURCE: Woofer connection peg snapped and need to repair?
Your best bet would be to go to a speaker repair shop, the Bose system should be worth a lot more than the modest price to repair the connector plug/socket. If you can't find a speaker shop locally look for one online.
Posted on Jul 04, 2011
bronk50
  • 27725 Answers
SOURCE: Low to no sound on
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Aug 05, 2011
95 silverado radio wires and colors (delco) trying to hook up a krnwood stereo?
If the factory plug is not cut off save yourself some time and trouble and do it right and buy the harness adapter at any car audio store, walmart, autoparts store. If not here is the color codesCar Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 16, 2016 | Cars & Trucks
Can i attach a 3.5mm 2 my speaker
I don't know what your skills are, But if it is a cable with two separated wires, that was connected with a 3,5 mm phone plug not that many can go wrong, as long as you put bot wires to a separate connection point of the plug. Be aware one of the wires is supposed the plus the other minus or common. If you revers this, it could change the case in the speaker, but perhaps you won't hear that.
On the one of the wired often is a white spot or line that can be seen over the complete length. That is how you can see the difference between + and -
If in the cable are a lot of wires, perhaps you should not start at all.
Don't make a shortage, to avoid you blowing up the amplifier.
Success
Jun 26, 2014 | Creative Labs Gigaworks S750 Computer...
04 toyoya camry radio wireing harness pin
Hi there:
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
- 2004 Toyota Camry Stereo Wiring Harness
- 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 06, 2012 | Toyota Camry Solara Cars & Trucks
I purchased pioneer speakers and am attempting to replace my stock speakers. Problem is there is already a plug and outlet on the factory speakers, which there is not on the new speakers. is this called ?...
yes they are called speaker harness adapters. You can just cut the factory ones off if you know the polarity (positive/negative) of the speaker wiring.
An easy way to find out is take a 9v or AA battery and two pieces of wire. Strip the wire and attatch one piece to the positive and another to the negative of your test battery, I use red wire for (+) and black for (-). Then take the other ends and touch the factory speaker connector (where it plugs onto the speaker). If it moves out or UP then you have the polarity correct and the wire that your red tester went to is the positive of the new speaker and the black test lead wire touched the negative. If the speaker moves in or DOWN then you simply have it reversed.
All pioneer speakers come with a set of wires so you can cut the factory connector off and put the new one on.
Sep 24, 2011 | Jeep Car Audio & Video
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Illumination Wire: Black/Red
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Right Front Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
Need a wiring diagram
HI,
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
please rate my suggestion....
May 22, 2009 | Car Audio & Video
I need the color codes for the radio wires!!!
PLEASE RATE THIS INFORMATION.
1993 Jeep Cherokee Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Mar 25, 2009 | 1993 Jeep Cherokee Country
My chinchilla chewed my speakers wires in half, can i get a new one? it is for lg speakers thanks, Jessica
Yes there are replacement wires for virtually every system on the market today. Note the make/model go to local electronics store and ask the sales rep the location of the speaker wires. The new wires should have instructions on how the remove the damaged wires and replace with new.
Oct 13, 2008 | Audio Players & Recorders
Speaker input cable
this happened to me before, try checking the ends on both sides and see if they are hooked up correctly, or look qat the whole wire and see if its chewed through or something.
Jun 10, 2008 | Car Audio & Video
Bose MediaMate Computer Speakers Logo
32 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
