Question about iRobot Roomba 530 Robotic Vacuum
Cleaned and running well, taken downstairs, put to work my 530 has developed a distinct knock. about 1/2 second speed as going along. does not happen if brushes removed. machine runs for a few mins th
Machine cleaned and looked after. not dropped etc. nothing i can find inside loose etc. no previous history of this, but can be seen in the machine progress ie a faint jump on one side as well as distinct knock. ? drive to brushes as stops if brushes removed
  • Mike Duffield Feb 13, 2012
    not sure how to say this but problem solved, despite care and a few years experience. I had not put the yellow collar on brush end properly, however stripped and cleaned the rest and gears etc all sweet quiet and effective. brill little device.
  • 430 Answers
I have this Hoover for 3 weeks
You left no details What make or Model Number But it sounds like an overload problem? is the vacuum restricted? Go outside Because things can fly out Wear Safety glasses and turn Your face away ! Remove all canisters, elements and filters this will allow unrestricted free suction does it continue to run Now If so You have restriction some were? If it doesn't run You said You had it 3 weeks it's probably an electrical issue return it for warranty replacement most stores are 30 Days so hurry ! if it does continue to run put it back together 1 component at a time testing each time , until the problem reoccurs theirs Your restriction .
May 19, 2016 | Hoover Vacuums
My rainbow E2 will run on High speed,but not the low speed.it's as if no power is getting to it,when.you try to switch it on low,but works fine on high
This could be one of two problems. It could be your switch is broken, preventing it from going to low speed. Try clicking it, does it still make a distinctive click sound, does it feel loose? If so it may be your switch: Rainbow e2 power switch
Otherwise if may be your computer in your E2 is starting to go bad. Often times if Rainbow stops going into one of the speeds it is due to a computer going bad. This is an expensive part and repair, so you should probably take it in and make sure it is the computer. Rainbow E2 controller 120v
800-775-6586
GoodVac com
Feb 13, 2015 | Rainbow Vacuums
Roomba 530 is fully charged, when I press clean it moves forward but after a second stops and flashes red any ideas how to resolve this problem
These are cool machines. If there is a battery it cold need charging or changing. If not, there is a sensor somewhere that just may need cleaning. Thats all I can offer right now. Let me know becuse my Dad has one and I will go over and check his out. Chris
Feb 09, 2011 | iRobot Roomba 530 Robotic Vacuum
Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Mar 14, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Roomba 530 runs for about a minute then stops and red light is on. Cleaned everything, still happens. Roomba is about 3 yrs old, lots of use.
Battery time! Get a nice new longer life battery on Ebay, or go for the Nicad replacement if you have no carpet and want to save some cash.
Mar 13, 2010 | iRobot Roomba 560 Robotic Vacuum
My irobot 530 is not collecting any dirt in its bin. Why would that be?
Most common issue is the filter is clogged try washing it out make sure you let it dry completely before putting it back in. replacement filters are available on ebay last time I checked they were 3 for under $10
The 530 uses a vacuum suction along with the spinning motion of the brushes to pick up dirt make sure its making a vacuuming sound if not could be only the brushes are moving and a motor has died on you.
lastly make sure that the brushes are spinning freely remove the tray that holds the brushes and clean it out with compressed air. the tray easily removes by first taking off the lower pan and removing the 4 screws that holds the tray in place. There are no wires to unplug when doing this.
hope that helps.
Jan 05, 2010 | iRobot Roomba 530 Robotic Vacuum
The upstairs portion of my cetral vac works fine. the downstairs portion never has worked.
There are two components involved here, wiring and pipe.
Have someone go to the vac and turn on manually, briefly while you go to an inlet on the lower portion downstairs and open the door. Then shut the vac off.
If you have suction downstairs at this point with the vac turned on manually , your pipes are all connected and the issue is the wiring for the lower level of the house. It will need to be connected to the wiring from the upper level. A good installer will have roughed in the system with the necessary wiring running along the pipe from each inlet. You should find a piece of wire hanging beside the pipe at each of the lower inlets. This low voltage wiring will need to connect to the main line by colored sequence. Your problem may be as simple as a bad splice where the wiring connects to the main line , or a second wire hanging inside the wall behind an inlet which has either come loose or been omitted. Do not unscrew the connection screws at the back of the inlet screws fully where the wires connect as they contain a spring loaded terminal which may fall apart.
If you have no suction, the piping has either not been connected to the pipe from upstairs or your lower piping is clogged. You will need to trace back and find your main floor "drops" in proximity from below , then connect them into the balance of piping for the system, being certain to connect the wiring at the same time. Post back with what you find and if you need more help.
Last of all if you actually have moderate suction on the lower level, but not enough , you may have blockage in the lower line or a leaking valve door upstairs. If clogged you will need to use another vacuum a ad draw the blockage out at a lower floor inlet, generally the one closest to the vac.
Please post to confirm what you have found.
Oct 13, 2009 | Vacuums
IRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
Aug 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Short run time
I turned mine over, and took out all the little tiny screws. There are 10 of them. Then 1 by 1 I took each gear out and cleaned the cat hair from around it, then put it back together. Mine works perfect now.
Be careful, I suggest disassembling one corner at a time and putting it back together as you go.
Good Luck
Feb 11, 2009 | As Seen On TV Swivel Sweeper Vacuum
iRobot Roomba 530 Robotic Vacuum Logo
75 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
