Question about Acer Computers & Internet
I can't change brightness
  • fawzy mohamed Feb 13, 2012
    i can't change brightness on acer 5742z ( fn key+ left or right arrow doesn't work )
    thanks
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Reinstall the chipset drivers ....if fails then try doing a system restore
Posted on Feb 13, 2012
Adjust brightness ipad
that is a basic thing to know:
  • Open Settings and tap on "Brightness & Wallpaper"
  • Adjust the brightness slider as desired
  • Flip "Auto-Brightness" to OFF to have the screen stop automatically adjusting brightness
adjust-brightness-ipad-fsa0em3gpfye3khtm1m3hcbs-4-0.jpg adjust-brightness-ipad-fsa0em3gpfye3khtm1m3hcbs-4-2.jpg Change Screen Brightness Stop the Display Auto Adjusting on iPhone
Jul 25, 2013 | Apple iPad Tablets & eReaders
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
Iam unable to adjust screen brightness in windows7
are you pressing the Function key first? the brightness buttons do not work without pressing that first. usually it is in blue close to the ALT.
& Win key
You can also change your brightness from the control panel, click on display then color setting, and you can see the contrast and brightness, as well as gama that does make it brighter or darker as well. Remember to write down the default settings.
these will not affect playing movies, the brightness adjustment for that are different controls, they can be access by the right click on the mouse during playback
Tony
Feb 10, 2013 | Lenovo G570
The dimmer switch on my 1999 firebird won't change the headlights from dim to bright, or vice versa. It has a good click to it and the blue light in the dash comes on when they're supposed to
That is a common problem, the switch needs changing if the high and low beams do work, the only problem is that it's an expensive part to replace, try a local wrecking yard they should have a bunch of suitable replacements at a reduced price.
Sep 19, 2012 | Pontiac Cars & Trucks
I have installed recently WIN XP SP3 on my samsung netbook N100. I observed the LCD gives sufficient brightness and Contrast when charger is on while with battery backup brightness & contrast...
I believe there's a setting in your control panel > power options to change the settings of the brightness and contrast depending on the source of power. it is set there to change the brightness and contrast of the LCD on how it will change once you remove the ac adapter from the laptop.
Hope this helps!
Sep 21, 2011 | Computers & Internet
How do i adjust brightness in hp g60
Here's how to adjust the screen brightness for a laptop in Windows 7:
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Alternatively, here is another way: From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers (f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be similiar. If you reboot the PC after using the function keys to change the LCD brightness settings, the brightness may return to the default setting on some models, which is based on the power source-battery or AC. This is not an error. The notebook is functioning as designed. If the notebook returns to the default setting after rebooting on your particular model, use the function keys to change the brightness back to the desired settings.
Aug 23, 2011 | HP G60-120US Laptop
I have brought a laptop of samsung rv 509. i have installed windows 7. when i started windows my laptop brightness is low. but when i plug in power then brightness is good. how to solve it? i have used...
Samsung has a built in great power management. It will reduce power brightness to 50% or less if unplug from power cord. <<< it gives more times for power on the battery stays longer. BUT if you demand for some cases eg.PRESENTATION >>> go to CONTROL PANEL >>>power option >>> presentation. APPLY >>> OK
akee_akee@live.com
Aug 16, 2011 | Samsung RV511A01 Notebook
Hey every one i have Toshiba Satellite L10-102 & problem was with screen light i can see the but very dark ? & i was think this problem it"s screen & i change the screen but still same...
It sounds to me like it's the invertor that's causing the problem. If you have already replaced this part (it's about 10cm's long, placed just below the monitor and about the thickness of a cigarette), then it's likely to be a cable or wire that's damaged or snapped. It may be worth wiggling the wires with the screen casing off, just to check.
I assume though, you have already checked to make sure you haven't turned the screen brightness right down by accident?
Aug 05, 2011 | Computers & Internet
I don't seem to have an option to change the colour on screen for my pro nav 300. It's sometimes hard to see in bright sunshine. Can you help please.
Lets see if we can help you. Lets take the bright sunshine issue first. You can adjust the backlighting on the device which may help that situation. To do this:
1) Click on the system icon. Then select the BACKLIGHT button. Now with the backlight menu up, tap the right side of the brightness bar (the top one) until the indicator is all the way to the right (bright sun). That should help some.
For the changing the colour issue, not sure if you mean night color options or color options themselves. For night color options, tap anywhere in the top 1/3 of the screen to bring up an options menu. Then select NIGHT COLOURS to change to softer night colours when driving at night.
To change the colour scheme during the day, according to the manual, when you turn the device on, it shows the setup screen. From within the 'Full Navigator' menu, select SETUP. From within this menu, should find an option for Colour schemes. Select this to choose the colour scheme that you'd like.
These devices always have many menus and aren't too easy to navigate. Hopefully these instructions will help you find what you're looking for. The entire manual for the device can also be found at:
http://www.pronav.co.uk/Downloads/ProNav%20PNN300%20(UK)%20User%20Guide%20V1.1.pdf
Hope this helps!
Cheers!
Jun 21, 2011 | GPS
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
