The@sign my key board works apart from the@ sign could you help please
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Posted on Apr 25, 2009
  • 35 Answers
So the "2" key works, just not the "@" key? That's strange... If you've got a keyboard that requires drivers, (Such as the logitech, fellowes, or microsoft) you can try reinstalling the keyboard drivers.
If that doesn't work, and you don't want to spend $5 on a new keyboard, you can use "Character Map" for the minimum of times that you would actually use the @ button.
In XP:
It should be Under "System Tools" in your start menu under "Accessories"
In Vista:
Just click "Start" and type "Character Map" (without the quotes) and press enter
When the program comes up click on the "@" symbol and press "Select" then whenever you need to put an "@" symbol in your screen, instead of pressing Shift+2 you press Ctrl+V.
That's the best work around if the driver thing doesn't work.
Posted on Oct 24, 2008
  • HelpfulGuy Oct 30, 2008
    Well I could have told you how to physically solder your keyboard back together, but considering it costs about $5 for a new keyboard my option was the best work around until you replace it.
    Thanks for trying? Just because the answer isn't "Press F3 and your @ key will work" (You didn't get an easy answer because there isn't one) there's no reason to ruins people feedback ratings.
Pressing backslash button it is showing hash sign.please help me with it
Change your language prefrenece to English (United States ) US Key Board)
Jan 27, 2013 | HP (C4768-60101) (C476860101) Keyboard
Hi i cant get the at @ sign on the acer iconia tab w500
Hi, On most key boards the shift key and the 2 button make the @ sign. Look where the @ sign is on your key board. You might be looking for a new key board. What do you have above the 2 ?
In the Fonts you maybe able to change to the @ sign. Good luck.
Jun 15, 2011 | Acer NSK8458AN Keyboard
On my TI-84 Plus calculator, all the buttons on my calculator work EXCEPT for the = sign. Can someone help me w/ this problem?
Just to try, please clear everything and press the = sign.
Try pressing it firmly and with a rocking motion.
Does the display flicker?
If nothing happens ...
I guess you know the answer to that.
Taking it to a service depot is an expensive proposition.
At this point you have nothing to lose, but you may have something to gain.
You can try taking it apart.
You'll need a small Philips screwdriver, some masking tape, some rubbing alcohol or the blue stuff used on fondues, a paper towel, and several Q-tips.
Make sure you have proper ventilation and there are on open flames anywhere near.
- Put the masking tape over the keys. This will help prevent them from flying all over the place.
- Remove the screws and pry it apart gently.
Remember, "Nothing to lose" is not the same as "Nothing to gain"
If it works you'll have a working calc again, and some new experience.
There may be two or three screws holding the little board in place. Remove them and gently again separate the board from the front plate.
There you'll see a rubber thinghie covering the front of the board. Separate it carefully.
You're almost there.
First wipe the board with the paper towel moistened with the cleaning fluid and put it aside.
Now thake a Q-tip, moisten it with the fluid and wipe each and every one of the little rubber protrusions. Get a new Q-tip every time it gets dirty.
Make sure there is no paper fluff on any of it.
Give it a few seconds to dry and start re-assembling the calculator.
If the problem was a poor contact, you have solved it.
May 31, 2011 | Office Equipment & Supplies
How to select euro sign on key board
please do the following and see will it work alt key+0128 you must use the numeric keys only goodluck
Apr 13, 2011 | Computers & Internet
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
Hi i have a satellite 4080 laptop when i want
You probably have either some liquid or some dirt underneath the keyboard that is not allowing the key to make proper contact. Your logic controller for the keyboard may also have been damaged. The key board can be taken apart and cleaned but I would not recommend trying to do that unless you have done this type of thing before. To be on the safe side you would be better off taking the notebook to your local shop and having them do a diagnostic on the unit.
Apr 08, 2010 | Toshiba Satellite 4080XCDT Notebook
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
Can not use a pound sign on my laptop
THIS MAYBE A KEYBOARD PROBLEM OR THE KEY BOARD SOFTWARE NEED TO BE RESET OR RE INSTALLED AND THAT MEAN A TOTAL INSTALL AS FIRST TIME YOU GOT YOUR MACHINE
Feb 02, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
834 people viewed this question
David Payne
David Payne
