Question about Vivitar Cameras
Vivitar series 1 li-ion battery pack charger
Need instructions
2 Suggested Answers
  • 13433 Answers
SOURCE: I need a battery charger
Hi
have a look at this one.
says to work with vivicam 6300
http://www.laptoptraveller.com/battery-charger-ch-9700.html
If that one is completely wrong. Then forget that one. And look at this one.
this one is ment for the Li-40B battery.
http://cameras.pricegrabber.com/digital-ac-dc-adapters-chargers/Olympus-LI-40C-Replacement-Li-40B/m8442588.html
Posted on Aug 01, 2009
What is part number zilog3055 on circuit board of DW9107 battery charger?
this 3055 ?
The zilog3055 device is a fully integrated, single-chip, pack-based solution that provides a rich array of features for gas gauging, protection, and authentication for 2-series, 3-series, and 4-series cell Li-Ion and Li-Polymer battery packs.
Using its integrated high-performance analog peripherals, the bq3055 device measures and maintains an accurate record of available capacity, voltage,
Nov 04, 2015 | Drills
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
Can a lithium be charged with a nicad charger
You are probably skeptical that maybe the directions telling you not to do that are just intended to get you to buy more stuff. We've all been there. However, Li-ion batteries are very different from nicads. Used incorrectly they can be downright dangerous. So, no, don't try using the nicad charger for the Li-Ion batteries.
Apr 12, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Cameras Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
