Question about Technics Audio Players & Recorders
The audio cord coming out of the turn table is cutting out
  • 86 Answers
If its an XLR Or RCA go to radio shack they carrie those audio cables, if it takes a phono cord they got those too, if
Posted on Oct 24, 2008
  • Ivan Mcdean
    Ivan Mcdean Oct 24, 2008
    sorry this stupid computer posted by accident, If you try to fix it your self it could cutt out more, thats what i was also trying to say, hope this works
I have a mastercraft 15A portable table saw (Product #055-6742-8). It's connected to a 50ft extension cord. When i turn it on the blade spins, when I place a piece of wood to cut the blade stops.
I think your problem is in the length of your extension cord. Either get a huge (10ga) or larger cord or move the saw closer to the wired power source.
Aug 26, 2017 | Blade Saws
Have 1959 Westinghouse table fan wit Leviton switch missing power cord. Need help rewiring power cord
120v?? Neutral stays neutral, hot goes through the switch and then your ground. Three easy steps, IF you turn the power off;)
Jul 18, 2017 | Heating & Cooling
10yr old table saw smells hot and trips breaker
Maybe, but first rule out several other things. Has the saw been recently overloaded - heavy cuts with a dull blade? You may have a partially burnt-out motor (which means the insulation on the wire in the windings has partially melted.) Has it been used recently or used now with an extension cord or to an outlet wired with 15 ga wire? Is the saw arbor hard to turn by hand (with the belt removed)? Does the motor overheat with no load (remove the belt and let it run for 10 minutes)? Try running the saw with the belt on, but not cutting for 10 minutes.
Dec 10, 2012 | Craftsman 10" Table Saw
I have a porter cable 6902 that when mounted to a table turns off. any ideas why?
You probably have a bad cord. Try moving the cord around with the router turned on and see if the power cuts in and out.
Nov 11, 2012 | Tools & Hardware - Others
Delta table saw, 34-670, keeps shutting down
There could be several problems. First, make sure you have a sharp blade. Then check the arbor for drag just after you have been using it. Unplug it, lift the motor a bit (to loosen the drive belt) and turn the blade with your hand - it should turn very freely. Check the motor shaft for drag too by turning the motor pulley with your hand (with the belt loose). The motor should have just a tiny bit more drag than the arbor shaft. If all of these check out ok, then you might have an insufficient gage of wire between the electric panel and the saw - a thin wire long extension cord is often a problem. If you are using an extension, try to eliminating it and plugging directly into the wall. (It depends on the length, but in general don't use a cord lighter than 14 ga - higher numbers mean skinnier wire). And it could be that the house wire is too light - a long run of 14 gage wire is too light - you want 12 gage wire and a 20 Amp rated outlet. If all of these are not the problem, then you have a bad motor that is partially burned out (that is, the insulation on the coil windings has melted and the coil wires are shorting out resulting in coils with a lot less turns than the motor was designed for. You can replace the motor or get it re-wound. Good luck!
Sep 11, 2012 | Delta Table Saw
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
How to replace the electric cord
If it is the power cord, it should be of the universal kind. If it is the RCA cables, youu will have to strip back the wires and solder the ends together matching the wire colors. Tape up with insulation tape and "bob's your uncle"
Jul 11, 2010 | Philco PC-841.651 Turntable
Porter cable router turning off intermittently during job
Hello. Yes it could be the extension cord or the outlet your pluged into or the feed speed of the cut.Try slowing the forward feed speed.
builderdale
Jan 24, 2010 | Porter Cable 75182 Variable Speed Router...
1 HP. motor wiring, need help!
Simple to do. Go to the local hardware or home improvement store and get a 6 to 8 foot heavy-duty extension cord. Cut the outlet end (not the Plug end) off, you won't use it. Strip back the outer casing of the cord to expose the three wires, black, white and green.
The Green wire is connected to frame of the motor or saw to ground it for safety reasons.
The White wire is connected to the silver color screw connection.
The Black wire is connected to one terminal of the switch, another wire is connected from the second switch terminal to the brass color screw on the motor.
Plug in the extension cord, and flip "ON" the switch and cut some wood and think of your Grandpa....good guy!
Sep 17, 2009 | Craftsman 10" Table Saw
Bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Nov 25, 2008 | Bosch 4000 - 07 Electric Table Saws
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
