Question about Car Audio & Video
I cannot get my radio to power up after installation
I 've reinstalled a panasonic radio "CQCI303U "in my 1997 cadilac deville, but it does not power up. Do I need to reset some codes, and how do I do thanks,
Ernie
You need to check your power wire with a volt meter or test light to make sure that you got power
and if you to you need to check your ground wire to make sure that its connected and got a good connection
Posted on Oct 26, 2008
WHAT IS Normal idle RPM for 97 Cadillac Deville ?
why dose my 1997 cadilac sevill always over heat
Apr 15, 2013 | 1997 Cadillac DeVille
1997 Cadilac Deville D'Elegance My air shocks are always low. Can I take off the tires; jack up the car; and fill the shocks with silicone and let them "harden?" The silicone that you use...
It wont work because the sponginess in the air shocks is due to the compressability of air. The silicone, being a liquid, will not compress. If you've given up on the air system, why not just replace the shocks with some good gas shocks?
Jun 26, 2011 | Cadillac DeVille Cars & Trucks
1998 cadilac deville running hot
when exactly does it run hot, does the cooling fan kick on at 225 Fahrenheit? does the AC radiator fan run?
Sep 17, 2010 | 1997 Cadillac DeVille
Installing a signal switch for a cadilac deville
it is a bit tricky if you have never done it before you have to turn the washer to get it out and back in
Nov 29, 2009 | 1997 Cadillac DeVille
Where is the radiator drain on 1997 cadilac deville?
The lower hose on the drivers side is much easier to get at than the drain I suggest you remove it to drain the radiatorl. You may be able to get to the drain if you still need to after removing the hose.
Jun 03, 2009 | 1997 Cadillac DeVille
Wont start
it is in the ignition it is a little small wire that is broken off and you need to replace the igintionjust hade this problem the worst time finding it out good luck
Sep 22, 2008 | 1997 Cadillac DeVille
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
