Question about Panasonic CT-36HL43 36" TV
Panasonic CT-36HL44J TV went dead, won't turn on.
When i tried to turn on the TV the sound and indicator light came on for a moment and then wnet dead. It won't turn on anymore. I tried switching to other wall outlets but didn't matter.
  • 525 Answers
Have check for fuse? is your tv cord good?
Posted on Oct 24, 2008
  • Demonic-2011
    Demonic-2011 Mar 10, 2011
    More likely to be a power supply circuit failure. Check the board and have a technician replace it if required.
Have a Panasonic CT-36HL44J hdtv, power supply is good, when powered up it acts like it wants to start but immediately shuts off, power indicator light blinks 8 times then pause then 8X (repeat). Spoke to...
According to a service forum (not FixYa), 8 blinks indicates Driver SOS 3 SS Board (SS energy recovery circuit) - in other words, the 8 blinks means a protection code for a faulty board/module. Unfortunately, this may not be repairable at consumer level; the TV will have to go to a workshop to have that board (if this model has it) examined and/or replaced (manufacturers no longer provide individual components for replacement; they lean towards replacing entire boards/panels/modules in their appliances nowadays). The only problem here is the likely cost(s) involved.
I suggest that you obtain a quote from an authorised Panasonic service centre, then you can decide for yourself if it is economical or worthwhile repairing. It's up to you.
- the error code/circuit failure can vary over different models.
Feb 04, 2011 | Panasonic CT-36HL43 36" TV
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
TV won't turn on. (Panasonic 1080i HDTV)
By the sound of it its a dead power supply im afraid :( It is very common for them models at that age very common... it may be cheaper to fix then buying a new one but ill let you decide that one but yea theres hundreds of people that have the same problem with them panasonic's bummer dude :(
May 04, 2017 | Panasonic CT-30WC14 30" TV
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
No power
to discharge your crt wont hepl you to switch it on . check the power supply first if they had B+ then check the horizontal transistor
Jan 19, 2008 | Panasonic CT-36HL43 36" TV
3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Aug 22, 2006 | Panasonic CT-32SX12 32" TV
Panasonic CT-36HL43 36" TV Logo
328 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
