Question about Hitachi Video Cameras
Out of synch
Hitachi dzhv592er
  • steve norcott Feb 12, 2012
    when I watch my playback on the t.v ,then there is no problem, but when I watch on my computer the audio and visual are out of synchronisation ,can anyone help?
    there is a big delay between sound and vision
Hitachi 53uwx10b
thats the sign of failed convergence. You can get the Hitachi DP14G convergence repair kit which also contains instructions from the following link http://www.tvrepairworld.com/hitachi_repair_kits then just scroll down to the DP14G convergence repair kit.
Aug 04, 2012 | Hitachi Televison & Video
Im seeing three separate colour outlines on people and objects red,green, blue
You have a convergent problem, where the red, blue, green projector lamps are out of synch. See: http://www.youtube.com/watch?v=esk4nYZKFcg for a pictorial on how to fix convergent.
Dec 29, 2010 | Hitachi 50DX20B 50" Rear Projection...
I can't get my Blueant to synch with my new iphone. It sits there and says Searching. It worked well with my old phone.
Un-synch with your old device by holding down all three buttons (volume up, volume down, and the main button) at the same time for 10 seconds. The Blueant will no longer be synched with your old phone and is free to synch with your new one.
Jan 01, 2010 | Blueant Z9 Wireless Headset
Have a 2003 hitachi model# 43F300. Colors are not in synch horizonally, blurred.
Sounds like convergence IC's Usually have to replace 2 IC's and some resistors and realign. Shop charges usually $200-$400. DIY?
Sep 22, 2009 | Hitachi Televison & Video
Ac compressor disengages 98 honda crv
Most compressor has a speed sensor to compare with the cranshaft sensor to prevent the compressor locked up.When you raised the RPM, after 15 sec, if the 2 sensors are not in synch then the computer thinks that the compressor is locked up so it disable the cluctch that was why your AC stops working. Check out your Compressor speed sensor. Good luck.
Jul 15, 2009 | Hitachi Heating & Cooling
Sansa synch problem
Change the Rip settings in Windows Media Player to convert the CD to mp3 format and then re-synch it - it will work. WMP probably synched it as a raw CDA, which the Sansa cannot recognize.
-Tha Mp3 Doctor
Oct 18, 2008 | SanDisk Sansa Clip MP3 Player
I have Hitachi CMT 2928FX, I am using AV input 1 on back, great sound, black and white picture that is just out of synch. I do not have the Hitachi remote, I am using the programable remote from DISH TV. I...
May be one of two things. With a standard av input (called Composite Video and usually colored Yellow) then the signal must be 480i, Standard Definition with (i)nterlace. If it is higher, say 1080i (another interlace signal but High Definition), 480p (Standard Definition in (p)rogressive mode), or 720p (another HD in progressive).
Try reseting the Dish receiver by unplugging it for 15 seconds.
Aug 18, 2008 | Hitachi Televison & Video
Photo's Won't Synch
worked for me
Nov 29, 2007 | Apple iPod Photo MP3 Player
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
How do I get the hotsync to sync everytime there is a change?
You may be used to PocketPC ActiveSync. HotSync is an asynchronous synch model - you synch upon demand but not continuously. Pocket PC devices synch all the time while in the cradle. There are advantages to both models. If you want to synch a Palm OS device, you need to press the button. There are some extra appliactions available on www.palmgear.com that will force your device to synch upon a schdule.
Sep 12, 2005 | Palm Treo 600 Handheld
Video Cameras Logo
65 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
