Ge washer wjre5550k2ww leaking at the top - Washing Machines
4 Suggested Answers
Bgillespie
  • 89 Answers
SOURCE: How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Posted on Dec 15, 2007
  • 1122 Answers
SOURCE: WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Posted on Jun 23, 2008
SOURCE: GE washer model WJRE5550K2WW -
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Posted on Jun 09, 2011
Ge washer wont shut off during spin have to shut off manually cycles thru all others wjre5550k2ww
Sounds like a timer/control issue issue..( you particular model has a control board instead of timer)..It would be best to call a professional to do proper diag and the repair but if want to risk it and attempt it yourself the part number is WH12X10439...
Good luck
Jul 05, 2017 | GE Washing Machines
My GE washer model- WJRE5550K2WW won't drain . it fills up and goes through wash cycle then when it suppose to drain you just hear a humming but it does nothing until it finally shuts its self off
It could be pump (if that humming comes from the machine, I assume pump works). So I would say it's clogged. You need to flip machine over and open it from the bottom (if you can), then there is hose that comes from the drum, take it apart and see that it's clean, if there is white ball in it, take it out, that ball is causing more trouble than it fixes. Clean the hose where it comes together with the drum and put everything back together.
Apr 04, 2016 | GE Washing Machines
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
I have a broken belt 175D5131P003 on a GE washer Model WJRE5550K2WW, or a P620. I realize the belt will have to be stretched a great deal to fit over the drum pulley and the motor shaft, but cannot figure...
Hello & Welcome to FixYa
You can view this video for replacing the belt in your GE washer:
Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Washing Machines
I need to adjust water level GE wjre5550k2ww, I need more water. I have well water so I not concerned about using a little more water.
you may need to check your pressure switch. if you have a mulitmeter use it to find any electrical issues. if you have no reading the switch needs to be replaced
Jan 31, 2011 | GE WHSB8000B Top Load Washer
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
Jan 05, 2011 | Washing Machines
I have a GE WJRE5550K2WW top load washer that we recently bought. This last weekend my daughter ran an experiment for a science class where she ran the wash cycle several times without letting the rest of...
yo creo que no puede ser el control puesto que no guarda memoria de los siclos me parece mas bien que pudo ser que se desmonto o se desgasto alguna piesa interna del mecanismo de la lavadora por el uso execivo al que fue expuesta para el experimento
Oct 05, 2010 | GE Washing Machines
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
