Question about Proview PL926WBi 19" LCD Monitor
Blank grey display
The monitor displays a blank grey screen with some darker vertical bars when it comes back from a powersaver power down or screen saver. I use a blank screen screensaver and am running Windows XP.
4 Suggested Answers
pishta68
  • 579 Answers
SOURCE: wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Posted on Apr 08, 2008
bammbammfran
  • 159 Answers
SOURCE: Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Posted on Oct 11, 2008
Fix-4U
  • 293 Answers
SOURCE: Displays a red laser like vertical thread
Hi...there,
Well...your lucks just run out...It's seems your panel are damaged. Repaired...don't bother, the panel cost twices what you paid for your monitor itself. Get a new one...and you'll saved the $$$ and all headaches...
Posted on Nov 21, 2008
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
My Toshiba M55 Laptop has a vertical 'ribbon' of flickering. Is it fixable?
Maybe your screen is going bad or the video card inside the computer is going bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the vertical ribbon then your lcd screen is bad and your video card is good. If the Borrowed monitor displays the same vertical ribbon as your lcd screen then your video card inside the computer has an issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Toshiba Satellite M55-S329 Notebook
After turning screen ix initially blank although backlight is on. Gradually vertical stripes appear of varying width and colour. Eventually lines change to horizontal bars howing sections of the correct...
Your display is faulty. Check out ebay for a replacement. Changing the display is straight forward. If you get your display we can instruct you on replacing it.
Hope that helps.
Nov 09, 2010 | HP Compaq nx6325 Notebook
LG stuck in powersave mode
Connect it to a different computer, e.g., a notebook computer,
and set the screen-resolution to 800-by-600, and see if the monitor works.
Change the screen-resolution to 1024-by-768, and try again.
Change the screen-resolution to 1280-by-1024, and try again.
Connect a different monitor to your computer,
and set the screen-resolution to 800-by-600.
Then, disconnect the "alternate" monitor, and connect your monitor.
Nov 25, 2009 | LG W1942TQ-BF 19 inch Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Gateway FPD2275W monitor power
there is problem with the video board . need services.
Apr 04, 2008 | Computers & Internet
Proview PL926WBi 19" LCD Monitor Logo
41 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
