Question about Samsung PN58B860 58 in. HDTV Plasma TV
Samsung PN58B860 shuts off, but caps look good
The tv never powers up. It clicks ever 30 seconds or so, but power never completely comes on. Tried replacing power supply, but this did not help. Still continues to have the same problem.
  • 2326 Answers
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to jah2mil@hotmail.com
Posted on Jan 05, 2009
video-tek
  • 150 Answers
SOURCE: LN-T4671 started clicking
hi, veeery common problem, bad caps in the power supply, put in higher voltage rated caps and it won`t happen again, video-tek
Posted on Jun 05, 2009
SOURCE: samsung lcd tv keeps clicking but won't turn on
ur tv needs a new ip board u can remove the back panel and its the center main board it'll be obvious to plain site being its the only unprotected board in the tv. get the model number from the top left of the part then go to samsungparts.com enter the part number order the part.this part is only about $130-$150 dollars and ur tv should be as good as new. the ip board is a simple fix just six screws around the board and seven wireharnesses just remove insert new part and and reconnect wire harnesses to correct slot that u removed them from screw back down and ur all set no big deal. dont ask samsung or a repair man they'll just screw u over and throw u around about ten differetn loops. not gettn a straight answer other then bring it n and charge u about $600 to fix. i see alot of people have this problem so there u go simple fix guaranteed. u r welcome.
Posted on Jun 13, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
milkburp
  • 416 Answers
SOURCE: My Samsung LN-T4061F makes a lot of clicking sound
Your power supply board needs some minor repair. I have a tutorial posted in my Tips & Tricks that can help you complete this repair yourself and save you some money (about $170). Check it out if your interested. I hope this was of some assistance.
Posted on Mar 28, 2010
Testimonial: "Thank you very much for the info. Never srealized this was such a major issue with SHAME-sung. Thanks again."
Why doesn't it turn on?
Modern Power supplies also monitor their load & other conditions and shut power off if a problem is detected.
Electrolytic Capacitors are the biggest problem.
Check for swollen or leaky Electro caps
Good Luck
How to Replace an Electrolytic Capacitor
Switched mode power supply
Feb 26, 2016 | Panasonic TC-P50X1 50 in. Plasma HDTV
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Samsung Plasma PN58B860 works fine for about an hour that a yellow error message "Not Available" shows up in the center of the screen and won't go away or allow power off without unplugging the TV.
Do you have a program preview button i.e. one that shows details of current program and the following program. When the message appears try hitting that preview button.
Nov 04, 2015 | Samsung PN58B860 58 in. HDTV Plasma TV
Samsung LN46A500T1F no power,
that" s main board problem . i meet one same stand so. replace back main board lcd tv working fine. try it. good luck!
Sep 06, 2012 | Samsung 460UX-2 LCD TV
Tv clicks on off after 30 min comes on power is ok verizon box cks ok
In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Nov 25, 2010 | Samsung LNT5265F 52 in. LCD HDTV
50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Jul 28, 2009 | Samsung Televison & Video
Jun 04, 2009 | Samsung LN-T4671F 46 in. LCD Television
Power
Possible fault on the power board or panel as the TV seems to shut off on a protection.
Need to investigate on these boards for any physical failure preliminary
before starting on a circuit check.
Oct 24, 2017 | Sanyo AVM-3257 32" TV
Samsung PN58B860 58 in. HDTV Plasma TV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
