Question about DISH Network 311 DTV Receiver
Sd dish reciever not recognized by hdtv tuner
  • Official Brand Answer
  • 263 Answers
Hey dgrines81!
I would need more information to provide an accurate solution including what model of receiver, but it sounds like you have an SD receiver hooked up to a HD TV.
Our SD receivers can show picture on an HD TV, they just need the correct cable. If your TV has the spot, I would recommend using RCA (Red, Yellow, White) cables. Plug those in to the receiver and the TV and then change the input. If the problem continues feel free to reach me here, or at thomas.faust@dish.com.
Tommy Faust
DISH Social Media Representative
Posted on Feb 23, 2012
Error 771
ok explain a little more please. Make sure U have the coax coming from the Dish (outside) going into the back of receiver where it says SAT in. or if it is a dual tuner (ie: 322 etc) make sure the coax in hooked up to the Separator. also make sure u are using the correct dish and lnb to match ur receiver. I ALWAYS do a "check switch: every time I hook up to a new/different dish just to make sure the receiver recognizes the LNB.
Sep 02, 2014 | Directv D10 DTV Receiver
HLN5065W not recognizing dish network
Hi Judy, my name is Mike Houston a Social Media Representative at DISH. I see there is a problem with the Samsung not recognizing the DISH equipment. I am happy to help you today with this issue. Are you not getting a picture or message on the screen? What type of receiver are you using, SD/HD? I will provide you my e-mail and you can contact me directly: michael.houston@dish.com
Oct 21, 2012 | Samsung HLN5065W 50" Rear Projection...
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
32" protron tv
an output like ( HDMI ) would be on a dish reciever , and a hdmi input on a tv would plug into that output on the dish reciever
Is HDMI what you are trying to connect? then you would need an HDMI cable
HDTV = High Definition television , which means that you have a built in digital tuner that will pick up the digital and high definition broadcast channels with an antenna connected to the tv
Mar 02, 2009 | Protron PLTV3250 32 in. LCD Television
Do I have digital tuner?
No, this set does not have a digital tuner. The TV must be an HDTV in order to have a digital tuner built in.
Dec 31, 2008 | Sylvania 6720FDF
Sound
You must be recieving a stereo signal for the set to recognize and offer the stereo option. That is more than likely why that option currently is grayed out...accordianman
Nov 26, 2007 | Toshiba 52HM95 52" HDTV Projection...
DISH Network 311 DTV Receiver Logo
70 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
