How do you install replacement memory to amilo pro series v2085 laptop
  • Steve Stephenson Feb 13, 2012
    Apparantly the v2085 has 2 slots-but they are not together.
    removed bottom panel and found one empty slot,have been told
    other is under keyboard -how do I find it -s this really is the slot
    I need to upgrade.
  • 32,281 Answers
Most laptops have an access panel on the bottom of the laptop. Remove the screw on the panel and lift off the panel. The RAM module/s ia held in place by clips on the edge of the RAM module. Push the clips to the side and the RAM module will pop up at an angle and then pull the RAM module off the connector.
When you install the new RAM module/s just reverse the process of removing the RAM module/s.
Posted on Feb 13, 2012
3 Suggested Answers
  • 26 Answers
SOURCE: How do I install extra memory onto my fujitsu
flip it over remove the littel doors till you find the mem then take them with you to a pc store thay will give you what you need..
Posted on Oct 07, 2009
drifterK
  • 4924 Answers
SOURCE: i have a very old fujitsu siemens laptop amilo pro v2085 that i have forgot the passwrod for, any help plz
OK ..
In case you are talking about the user account password...and you forgot it ...the only way to log in is to reinstall the operation system using a boot-able disk with the operation system on it ..cause it is an old one I believe you use windows xp on it ..and the way to proceed is to restart the computer with the boot-able disk inside ..and press f12 for the boot menu (or the key indicated on the screen on start for boot menu ) ..and select the cd /dvd as the first boot device ..and press enter ..when it starts you will be prompted to press any key to confirm the booting from the disk ..
If all operation I described seam impossible to be done ..(cause you don't hit the right F key 0 ..just press f2 and go to bios ..and under boot ..select the CD to be the first device to boot from ..and the hard disk the next in line ..and save the changes with F10 and restart ..It will always boot from the disk first if it has one inside or will go to the next boot device ..
If you do not have a boot-able disk ..try to bowwow one ..or you can download a image file with the operation disk from the internet ..and burn it boot-able with Nero or isoburn or other image burner program ..
to find an image look on torrent sites like pirate bay ..read first about the image before downloading ..and be sure it is the right one ..(they may be in other language or needing a certain platform ..(on 64 ) ..If you have Nero installed ..just double click on the image ..and be sure you have a blank CD inside to burn into ..It will make it boot-able if you proceed this way ..I mean directly burn and not adding the files from the image ..but clicking on it to start with Nero automatically ..
Good luck !
Posted on Dec 15, 2011
I have instaled windows 7 on my fujitsu siemens amilo pro v2085 laptop the sound card is instaled but no sound. The fujitsu siemens FTS system diagnostics did not find any problems, but no sound. What...
Download the drivers from Fujitsu or it will never be correct. Once you have all required drivers, it should be fine, assuming Fujitsu support Win7 that is.
Dec 27, 2010 | Computers & Internet
Amilo pro v2085 30B0-51c5-0607-fd41-86ca S/N 914d3z1008g63601424k00a Plese i forgot bios password could you please help us by providing master password. Thanks regards Nasir Khan
If i gave you the master password then everyone would have it. Go to the Manufactures web site and look-up resetting bios pass word you will have to remove the 3 volt button battery.
Nov 24, 2010 | Fujitsu AMILO PC Laptops
I would like to transfer from a sandisk memory
get a memory reader. or install your sandisk driver into your laptop so it can work connecting your sandisk into your laptop.
May 02, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do i turn my wirless connection on my fijitsu siemens amilo pro
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Gateway Laptop ---- Switch on side and then Fn / F2
Apr 02, 2010 | AT&T Siemens S46 GSM Cellular Phone
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Can i replace 1 Gb memory (for fujitsu amilo mini
your amilo 3520 can support up to 4gig memmory that would be 2x2gig
Oct 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Does pc2700 ddr sodimm 333mhz ram memory compatible with Intel 852/855 GM/GME chipset?
As far as I can tell, the Amilo Pro v2000 was one of the Amilo A series. As you do not state the specific model revision, you should be able to find the information you are looking for here:
http://uk.ts.fujitsu.com/home/products/notebooks/notebook_archive.html
You will need to match the exact model number found on the bottom of your laptop to the relevant data sheet
Oct 15, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
How do I install extra memory onto my fujitsu siemens amilo pro v2085 laptop
Oct 06, 2009 | Computers & Internet
Fujitsu-Siemens Amilo Pro V2040 Laptop memory locations?
Sorry, This laptop only supports one memory card slot upto 1.7GB
Mar 15, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
